If u connect to the repeater, yes the speed will drop..
But the repeater and the router has the same name leh. Like cannot choose one leh
All the setup instructions on here seem to be in relation to Singtel i.e. presets and CT1/CT2.
Anywhere I can look for specific instructions for Viewqwest? Can I connect directly from the fiber box on the wall to AC87, or do I still need to use the zhone router?
Hi
I set up the Prolink WNR1004 as wireless access point for me to use my tablet, phone etc in my room as the wireless strength from the main AC87U in the hall is not strong enough.
I want to set the prolink as AP but the mobile device is unable to obtain IP address fr the AC87U. Then i set the prolink to router mode. its able to get internet access via the media bridge unit. meaning i cant have "access" to my other device connected to the main AC87U unit.
firmware latest 3.0.0.4.376_2678
Its the mobile device like iphone 5, sony tablet xperia and xiaomi 1s they are unable to obtain ip address from the AC87u to be connected.Dear cochran,
You need to play around with your system settings on network drive.
Nothing to do with RT-AC87U settings.
Best regard,
JK
Zhone is a ONT cum Router device, no way you can replace it with AC87 completely !!!
Lets not talk about network drive first.
AC87u unable to assign IP addresses to the mobile device when connected to the prolink WNR1004 when set as AP connected to the media bridge AC87u unit.
Pls advice.
Thank you.
Read that the AC87U antenna is specially designed. SO izzit wise to change them?Just a interesting question:
If I replace all 8 of my AC87U antennas with +9dB, +12dB and +15dB ones (there are some selling in Amazon), will it max the 5Ghz wireless bridge to hit close to 1Gbps cap?
Any way to order these, seems didn't see them on retail stores.
I also want to know. I got one of this sitting around.Just a interesting question:
Hi,
Want to check where to buy this router now. Missed it in COMEX
Checked in funan challegener also dont have..sigh..
I may wanna change too as my signal strength is not strong enough to get to my room.
Pc themes in sim Lim had stocks today!
