Xiaomi Redmi 1S thread
mingfreakrsx
hengheng220
Guys just flashed it to the original android OS 4.3 rom from the miui forum. Running even better than Miui, uses lesser ram and stuffs. But lots of work to be done to flash it over. But IMO, its definitely worth the effort.
adix_82
In case anyone don't know, Xiaomi has released a ROM update for Redmi 1S that (finally)solve the default camera app not able to save photos/videos taken to SD card!
Flashing ROM guide for Redmi 1S: MIUI ROM Flashing Guide for Redmi 1/1S - Redmi 1 - MIUI Official Community
Download the ZIP file below!;)
Does it prevent drop call.. the snapdragon version is dropping call till my hair is dropping. .
erwinseow
Hi Redmi 1S users,
I have an existing Redmi 1. Can I just take out my SD card from Redmi 1 and put it in the 1S? Will the 1S be able to read the contents of the SD card without any issues?
Thanks!
Erwin
renfred89
Hi Redmi 1S users,
Thanks!
Erwin
can.. no problem..
hengheng220
Thanks!
If install 3rd part keyboard, should be less buggy right?
Yes but regardless what keyboard u are using u still need to install the original Google keyboard first somehow or it will keep pop up saying Google keyboard crash. Not sure why though
bayugiri78
bro, care to share which thread you followed to have this change?
twist_shout
can anyone show me a guide one how to go to recovery mode? i will like to format the phone over there. But when i press the vol down + power button it jus stuck at the fastboot pic
when i do a factory reset and del all apps in the MIUI. my previous installed app s is still there...:s11:
zenify.me
updater > press menu button > reboot to recovery
