iPhone backup
tennisguy
Same problem happening to me :(
I repair and re-install iTunes and still taking ages to sync.
Unable to put in new songs :(
szeli
so did u try some of e solutions mentioned in this thread?
ahbear82
seems like more and more people facing this issues, can anyone high light this natters to Apple?
Anyone try reformatting the PC, see if it works?
revogsx
kill all apps in iphone, reboot phone. then try put in airplane mode.
then create new user in PC. then backup on pc.
check if you other programs running in background.
maybe try disable antivirus if you have
HeyYouThere
Tried almost everything but fail..
Only thing I haven't try yet is reformat comp.
Actually mine still <1 year, you think I should try go 1 for 1?
Orange Liao
Hey there,
Need advise :(
I have updated my itunes to IOS 7.1.2 yesterday. And has successfully sync my new songs into my iphone 4.
However when i attempt to backup my iphone 4 on both my computer and icloud, a message popped out saying "itunes could not back up the iphone because a session could not be started". I have also tried the following suggestions from other websites but couldn't help:
- restart computer, restart itunes and restart iphone
- delete my previous backup found under preferences -> devices
- clear up my computer space
And situation got worsen when this syncing session clear all my calendar schedule and now my calendar is left emptied.
Any experts out there can help to provide remedies?
HeyYouThere
Hi just something to share for those who are unable to connect to the iTunes store.
1. Start
2. Command Prompt
3. Type in "netsh winsock reset" (without the "s)
4. Restart computer
Worked for me.
