Sept 2014 BTO Launched !!
Gixxerfied
Application Results:
Click Here!
OCS:
West Terra @ Bukit Batok
Buangkok Edgeview
Buangkok Square
Yung Ho Spring I & II
St George's Towers
3D Models:
Buangkok Edgeview
Buangkok Square
St George's Towers
Maps & Flats Availability:
Buangkok Edgeview & Square
St George's Towers
Sales Brochure:
Buangkok Edgeview
Buangkok Square
St George's Towers
Additional Tools:
Sun Calculator
Can use to have an estimate of the sun position at different month of the year and how it affects the unit which you're eyeing.
HDB Loan
HDB Loan Excel Sheet..Might come in handy for many..
minoyo
roughly when will the result be out ? i mean getting the queue number.
380002
Whampoa pricing not as bad as I thought??? Confirm applying! Praying will get a queue number this time round :)
jmoomoo
trying my luck for boon keng =/ abit too expensive.. 4 room 459k to 574k.
currypig
Housing Development
St George's Towers
Selection Date (Median Month of Selection)
Nov 2014 to Apr 2015 (Feb 2015)
Estimated Completion Date
1Q2019
Estimated Waiting Time*
49 to 50 months
Estimated Delivery Possession Date^
31 Mar 2020
pinkibeee
Is there a difference between applying for public scheme and fiance/fiancee scheme? I'm applying w my bf but the form states public scheme. Will it make a difference?
currypig
you have to put as fiance/fiancee scheme if you have not registered with ROM , as you will be putting your marital status as single.
daemyn
Housing Development
St George's Towers
1Q2019
49 to 50 months
31 Mar 2020
OMG 2020 sounds like eons away. 0__0
pinkibeee
Our marital status is single and co-applicant relationship to main applicant is fiance/fiancee. But when I got to the last page, the form listed us in the public scheme.
Gixxerfied
Yes it's correct..
Married 1st timer(Without a kid, not living near parents) and fiance/fiancee would be under public scheme..There is no additional ballot tickets for married 1st timer couple without a kid or living near parents or fiance/fiancee application.
Submission of Marriage Certificate
If you are applying for the Additional CPF Housing Grant (AHG) or the Special CPF Housing Grant (SHG), you must submit a copy of your marriage certificate to the HDB on or before the date you take possession of the flat as these housing grants are meant for married couples.
If you have solemnised your marriage before you collect the keys to your flat, you will have to submit a copy of your marriage certificate to our Sales Office.
If you are not applying for the AHG or the SHG and you have booked a flat that is completed, you must produce your marriage certificate within three months after you have taken possession of the new flat.
If you are not applying for the AHG or the SHG and you have booked a flat that is under construction, you must produce your marriage certificate at the estimated Delivery Possession Date of the flat or within three months after you have taken possession of the new flat, whichever is later.
If you solemnise your marriage after you have taken possession of the new flat, you will have to submit a copy of your marriage certificate to the HDB Branch managing the lease of your flat.
Additional Info on FS
Unless you're applying under MCPS then it would be a different scheme..
pinkibeee
Yes it's correct..
ahhh. thanks for the info!
michael_thm
2 room BTO locations are getting from bad to worse. Was planning to skip Sept BTO and try Nov BTO... but Nov locations are just as bad. PAP need to be taught a lesson in GE2016. :mad:
otaku7
sep i'm skipping.
planning for the 2rm nov at sengkang one.
but the no. of units there is :s22: total 500+ unit inclusive of 2/3/4 rms.
most likely 2rm will only have 100 units.
but i'll still try for it as i want to be still around sk area.
