Y is the box smaller?
otacon
My friend just got a used iPhone 5 from someone but realised the box is much smaller than other iphone 5 box. N it does not include the charger plug. Does it mean this is not local set?
Andread
it may be the packaging they use for refurbished models.
i think worldwide, the boxes are the same, so that alone cannot determine local or overseas set.
chardz88
u can differentiate the country by the plug... singapore set is 3 legged... others are different...
kerrying
All original Apple iPhone retail packaging are of identical size, no matter what type of power adapter (the plug) is included (European or not, 3 pins or 2 pins..). And all original Apple iPhone retail packaging comes with a power adapter.
tec_geek
If I'm not wrong, the U.S. box is slightly thinner than the UK's. But all should include the respective countries' power adapter, Lightning to USB cable and Earpods.
Probably you have gotten a refurbished box which is very thin to just fit the iPhone in.
otacon
but I think there is slot for earpiece, charger cable n something else but I dun know what
Any pictures? or color of the box? Brown?
Later go back n take photo
Sent from GAGT Android App
xiaobai1
Did you confirm that it is an iphone? :X And he bought an used iphone from someone and the person didn't give him the charger head? How about the cable? I hope he got it cheaper because there wasn't those accessories inside.
otacon
Confirmed is iPhone lah, using it for few months liao, even updated to IOS 8.0.2
When he bought the phone, the seller already mentioned no charger plug but got cable
The serial number n imei even matches the box
Quite surprised not much ppl can confirm y the box is smaller
Earthling
iphone boxes are white. but well, not surprising, theres online websites selling the box alone. its possible to have customised boxes? :s22:
ragnarok95
Senior Moderator
Senior Moderator
For iphone 5, white comes with white box. Black comes with black box.
htngwilliam
Box look very weird lei. I don't know about IPhone 5S but IPhone 6+ black comes with white box also
UGeene
Box looks normal. Look at the wall plug holder. Definitely not our 3 pin type. Looks more like the 2 pin type used in the US. Should be an export set.
kokfann
my black iphone 5 also comes in black box. ordered from apple store. there is nothing strange with it
szeli
what is e model#? can check from settings > general > about
