iPhone 6/6+ Screen Protectors
garychengjw
2 from the Qoo10, price different so much?
Then this one is selling for $8.90 only?
Qoo10 - [Healing Shield] Premium Screen Protector Film 2pcs for APPLE iPhone 6... : Smartphone / Tab...
Promotion mah
Momolane
Guys any top few tempered glass sp available to recommend? Mine kept small crack on the side of the sp..changed two sp already ):
gapboy
Did mine at sim lim square 4th floor for $20 standard size of the tempered glass SP which doesn't cover whole scree due to curve.
I go again because i did change once with them with my note 3 $15 and seems quite ok the quality and didnt want to spend $30-$40 for spigen which i tried the oleo-phobic coating doesn't last.
Momolane
Did mine at sim lim square 4th floor for $20 standard doesn't cover whole screen.
I go again because i did change once with them with my note 3 $15 and seems quite ok the quality.
What's the shop name... Heart pain the side of the screen cracked when just changed not long :(
gapboy
I dont know the name but if you take the escalator 4th floor turn right is the shop they have alot of SP hanging near the outside and sell accessories inside.
You can see a few brands they have one of them is remax.
Momolane
Thanks bro...
happychai
got mine from qoo10
brand 9h, quite good quality and same problem with other bro as the SP does not cover the whole screen
Kyubi
hmm i hoot liao then i realize . . is it matt or clear??? cos i dont like matt z
fotoss
Anybody using invisible skin like extreme guard or Zagg?
Is it difficult to apply?
vade
i am planning to get a film screen protector to use while waiting for the curved glass ones. any recommendation on which brand and where to get? how is the spigen crystal one?
foopower
Have you guys noticed only when Apple came out with a curve glass, all of the SP manufacturers will try to innovate and come up with a new technology to fully cover the edges whereas when S3 came out, they didn't put in effort to cover the curve edges.
This! Because of economies of scale, I noticed most Samsung users aren't really keen on spending much to protect their babies. Which includes me.
But then I don't splurge much on my iDevices too :D
