iPhone 6/6+ Screen Protectors
deep3lue
This is wet application which is easier.
My guess is that this will be the same sticky surface that will turn yellow in time because the description fits exactly like the Zagg type down to the material of the film too.
Maybe need someone to buy and review.
alan_shearer
i just got the 6 normal..
pasted tempted screen but was told corner side cannot cover due to design...Paid $15...
knn...
anywhere got sell full screen cover...include my side edge? plus installation
not using the phone till this is resolved....stay with my 5
as far as I am aware, there isn't a SP that covers everything.....
wolfverine88
Definitely not the tempered glass ones as the sides of the IP6/+ is curve and right now, no one is able to come out with curved tempered glass.
However, for those "normal" ones that are not tempered glass, it did cover quite a fair bit of my +. I tore it off when I got my tempered glass one. In fact, now that I have the back protector on, I am inclined to use the phone naked!
yes so far been trying to find one but dont have.... the screen protectors or glass encoutnered so far all never cover the front surface fully...
salac38
is a back protector really necessary for this gen? i understand it is necessary for 4 - 5s as those gen had glass backs.... this one is just an all aluminum back
seeker
Tried 2 different brands,
1 :- Hardness (10H)
2 :-
Both are quite good but the first brand has no Oleophobic Coating so will have lots of fingerprint marks.
Cost:-
The second is much better as it has Oleophobic Coating (9H) so you don't notice finger print marks; just like the screen of the iPhone 6
Cost:-
If you don't mind the higher price for the ITG than its a better screen protector to use.
Anyway YMMV as this is my personal opinion.
Photos taken on the iPhone 6
wolfverine88
Yes, you are right esp if you already have a casing. However, now that it is on and esp my current case is quite bulky (Spigen Hybrid), I realize that carrying it naked really makes the phone so slick!
seeker
ITG doesn't cover the whole screen. It require great precision to make tempered glass screen for curved surface otherwise I believe there will be air bubbles.
speedster4005
The ITG Max does. I am waiting for some pics from a colleague. Here's a snap of the back of the box:
Benimaru
Guys I have 2 spare iphone 6+ spigen screen protector to let go as I've bought the 3 films in on pack. PM me if u wanna get one off me. Thanks!!
Benimaru
How's the oleo coating after days of use?
Had it on since day one of iphone 6 launch. Smoothness of the screen is there but fingerprinted easily. Maybe the coating starting worn off already. I'm not sure. But it's still nice to slight ur finger around. Smooth
darren89
Actually if the iPhone screen hardness is 8/9H, then those plastic sp with hardness of 3 - 4H will be more suceptible to scratches, leading to the screen becoming blur .. No?
I
chiaster
Yes, I should think that it goes to the edges too. Otherwise, it wouldn't be called "MAX" to differentiate itself from the rest of the ITG variants. Waiting anxiously to see actual pictures.
