funan Centre diy shop
bundy
Any good shop to recommend? Need a new case and got capitaland vochours to spend...thanks
FlyingNuggets
theres only 2 shops that i personally recommend which is Asus pc vii diy and the one near it i forget the name! i think its make fine
FatalityV
You need people to help you diy, or you just want a shop that sell component seperate?
shiodong
funan has limited diy shops. i'd say just tour every levels, see nice case, hoot the vouchers and say sayonara in an hour's time...chop chop currypok.
mav3rick
nobody can read? he has capitaland vouchers, n unless SLS is uder capitaland, i dun see any other way...
trenzterra
That time when I wanted to use my SAFRA $100 voucher (converted to CapitaLand), I went to 'Inforcom', I think it's on level 3 or level 4 at the escalator there.
Prices are definitely more expensive, and sometimes not updated. You may want to see if they can match the prices or not (or offer it to you a little cheaper), I managed to do that once.
I bought my sound card from them. They sell quite a lot of peripherals. Not sure about cases but if I'm not wrong (but I may be!) they sell a few over there.
Best to call before going down. Google for the number yourself haha.
shadow84
Capitaland vouchers can be used in other areas like grocery shopping, dining, etc. No need to use it at funan for DIY pc. If looking at value-worth, buying from sls can save more than getting at funan.
MoneyFace =p
He can get his chassis for free if he shop at Funan.......
shadow84
Then, any shop should be fine bah, since its 'free'.. As long as the shop is selling within the amount of capitaland vouchers that he have, and if he knows the SRP of the case that he want. Can take reference from cybermind or pc themes.
bundy
Manage to find out cybermind has a branch, likely to get my case from them
hengheng220
But ts depending on your captialand voucher worth how much. Might not be worth getting from funan if it only discount a bit.
Jian19
So many reply without open eyes reading TS first post :s22:
