[DIY] Urgent advice needed on new PC
outlander
Hi folks, I have not been following the PC scene for years. My current 6-year old rig running Intel Core 2 Quad and GTX 560 has just died on me. Would appreciate any kind advice for the following parts.
I play RPG games like Skyrim occasionally. Not really into FPS so the graphics card don't have to be too high-end. I'm not an enthusiast so will not be overclocking or using dual graphics cards.
1. Processor + mobo (i5 or i7?)
2. Graphics card - budget around $300
3. SSD - please recommend a value-for-money option. Preferably 500Gb
4. Hard disk - thinking of WD Green 4Tb
5. Ram - Kingston value ram 8Gb x 2 (?)
6. Decent power supply
7. Nice casing (maybe mid tower) - budget less than $200
8. Win 8.1 OEM
I don't have a hard budget but would prefer to spend not more than $1500 for the above. Thanks.
My last system was assembled at PC Themes. Are they still recommended? Or are there new players nowadays?
FlyingNuggets
8. Win 8.1 OEM
i5 is enough for gaming , 8gb is enough.. and ram is upgradable anytime so you can just get 8 now if 8 really not enough then buy one more piece 8
casing is up to you to walk around and see which one you prefer
save money on processor ram casing and put more on the GPU.. If im not wrong i think with your 1.5k budget can get GTX 970
outlander
Thanks bro. I intend to spend only around $300 for the gfx card since I don't game regularly. Hence would like to know which is the best for that budget.
Jian19
i5-4460 + Msi b85m g43 ~ $363
Crucial 8gb ddr3 ~ $100
Crucial mx100 512gb ssd ~ $315
Wd red 4tb ~ $235
Zotac gtx750 ti ~ $219
Seasonic s12g 450w ~ $89
Sharkoon bd28 ~ $79
Win 8.1 64 oem ~ $130
$1530 buy and DIY @ pctheme ask for discount. Your storage basically take up roughly 1/3 of ur budget :s22:
FlyingNuggets
Wd red 4tb ~ $235
Sharkoon bd28 ~ $79
wah! why so big the ssd?
FlyingNuggets
or you can get a better second hand card if you dont mind? you can go marketplace and check it out. You get a better card it might last you abit longer then the budget cards
Btw do you really need such a big ssd? as ssd now are still expensive its not really needed to use ssd for normal stuffs other then boot ups
outlander
Wd red 4tb ~ $235
Sharkoon bd28 ~ $79
Thanks for the quick reply. I guess I'm really out of touch.
- I'll go for 256Gb SSD since 512Gb doesn't seem worth it. Is Crucial better than Samsung EVO?
- Any reason why WD red is better than green? I don't intend to go for RAID.
- Can recommend a better gfx than 750ti? I don't mind paying slightly more than $300.
FlyingNuggets
amd r9 270x?
Jian19
I believe Samsung have a better software support for their ssd, that's about it
Crucial mx100 256gb is roughly $155 and Samsung evo is around $20 more
Red is much better built compare to Green, more durable and Quiet compare to Green
If u can wait, gtx960 is coming, it should be below $400 if u going for brands like Zotac or Leadtek which use decent cooler but not so good in OC compare to Msi or Gigabyte. That card will be ur best bang for bucks. However since u dun game much I think a 270 might just works fine or u, pricing @ roughly $260
FlyingNuggets
This is a good choice but if you cannot wait you can buy a second hand card? i saw some people are selling power color HD7970 for $250
Jian19
Might wan to consider using the extra budget from ssd and invest a better psu or case
Seasonic g550 ~ $125
Fractal design arc midi r2 ~ $130
nippp0n
CPU & Mobo: i5-4460 & MSI B85M-G43 @ $336
Ram: Crucial 1600mhz value ram 8GB @ $100
ODD: Samsung DVD RW @ $21
HDD: WD Red 4TB @ $224
SSD: Crucial MX100 256GB @ $155
GPU: Zotac GTX 760 Amp @ $329
Case: Fractal Design Arc Midi @ $129
PSU: Superflower Leadex 650W @ $139
OS: Windows 8.1 @ $120
Total: $1553
Buy from Tradepac and DIY.
outlander
Thanks to all the brothers who replied. Just went down and got the system from Tradepac. They agreed to assemble for me.
i5-4460 + MSI B85M-G43
WD red 4Tb
Crucial MX100 256Gb SSD
Crucial 8Gb PC1600 DDR3 x 2
Powercolor R9 270 2GB
Seasonic M12II bronze 620W
Fractal Design Define R4
Windows 8.1 64-bit OEM
Total damage: $1540
Jian19
Must see how they assemble and check ur stuff b4 leaving :o
nippp0n
WD red 4Tb
Total damage: $1540
Gaming only, no need to get 16gb ram la.
How come never consider GTX 760? The performance should be better than R9 270.
outlander
Keeping fingers crossed. Going to collect later. Don't think I will be able to check on the spot but I suppose I can always go back to them if anything wrong.
outlander
Kiasu abit since ram so cheap nowadays. GTX 760 is significantly more expensive than R9 270.
