Microsoft Surface
Livewings
OK I have tested 3 SSD UASP enclosures and they all perform more or less the same with the Samsung 850 Pro 512GB SSD. All transfer at a speed of about 240MBps.
This is now being confirmed to be the speed limitation of the SSD inside the SP3....if you ask me.
Try disabling BitLocker. It should speed up the SSD quite a bit.
eyz
Thanks, bro!
Any recommendation for a affordable one?
I intend to use it with my SATA II HDD.
eyz
Also, what is a good USB 3.0 flash drive to install program on it? Prefer it to be low profile.
Apparatus
Re
Thanks, bro!
Then just buy a SATA II-to-USB 3.0 enclosure will do since the limitation is now on the SATA II HDD
E_T
Bro,
any updates on your HDD enclosure result?
I'm also considering getting one as well.
I'm reading reviews of this SSD & it seems the maximum real-world read/write performance is half of the maximum write speed at 246MB/s. That is paired to a SATA3 interface with dedicated read/write channels.
Since UAS emulates SCSI, when copying files on NTFS volumes, maybe the behavior is the same? Like I mentioned previously, best to try on another PC.
Apparatus
Re
Since the SP3 does not support 3G/LTE is it possible to connect to an external modem like the Huawei E5786 or the Samsung Note 4 to surf at 4G+ (300Mbps) using Wi-Fi connection?
If yes, how?
According to the Note 4 spec here it seems the SP3 can be used as a WiFi hotspot
http://www.gsmarena.com/samsung_galaxy_note_4-6434.php
Thanks
Myu~sun
I think it is first 45 days of receipt date.
Ya . The live chat personnel bluff me .
The personnel inform me that if I'm unhappy with the surface pro within 15days of purchase can return it with no charges . Full refund will be given .
Not sure if it's true . So far just back from Bangkok haven open it up . Gotten the i5 128gb with black type cover & docking station at student price .
Livewings
If yes, how?
Samsung Galaxy Note 4 - Full phone specifications
Thanks
Turn on Mobile Hotspot in Settings.
If you own a Windows Phone like me, you can connect to the hotspot without turning it on first similar to the Continuity feature in iOS/Mac OS.
Myu~sun
Where do you all get the skin / tempered glass from ? I saw from sum1 posted adix82 and Nicholas . What's the price they selling r ? As for Nicholas is at where r ?
Apparatus
Ok got it. Now surfing super fast using Note 4 on StarHub at 4G+ in Jurong East Bus Interchange
Thanks
eyz
miragez
For skin and tempered glass you can find Nicholas at Sim Lim Square #05-26B, for adix82 he is selling case and tempered glass only.
You might want to search facebook of adix82 or lappyskins facebook, each of them have their numbers there for you to contact and ask, as prices might change so I cannot confirm with you anything.
miragez
waiting for the casing and screen protector i ordered from Qoo10.
Leather Flip Case for Microsoft Surface Pro 3 14160
Qoo10 - Leather Flip Case for Microsoft Surface Pro 3 14160 : Smartphone / Tablet
[Microsoft][Healing Shield] MicroSoft SURFACE Series (SURFACE Pro SURFACE Pro2 Pro 2 SURFACE Pro3 Pro 3 SURFACE RT SURFACE 2) - Made in Korea
Qoo10 - [Healing Shield] MicroSoft SURFACE Series (SURFACE Pro SURFACE Pro2 Pr... : Smartphone / Tab...
Is ur screen protector glass or plastic material ?
eyz
I just installed Chrome, and hasn't encountered any heat issue.
It should be solved with the update, right?
Need Chrome to sync all my bookmarks.
eijnaix
Just got an extra brand new un-open online exclusive RED surface pro 3 keyboard. letting it go at only $150, self collection at kembangan mrt station...any bro here interested give me a pm
xonix
May I know if owners of SP1/2/3 have any issues getting display output on consumer TV via Mini DP to HDMI adapters ? I can't get mine to detect any HDMI signal at all.
It works fine if I via Mini DP to HDMI + HDMI-DVI cable but I want the video+audio advantages by connecting via HDMI. It also works fine if I connect it wirelessly via Miracast. Currently using the latest Surface Pro drivers.
I have tested using graphic drivers directly from Intel. The wired connection doesn't work and Miracast also doesn't work too when using non Surface Pro certified drivers.
