any one encounter batt drain fast ? i let the phone idle few hrs and drop to 70% wtf..
Hi Bro,
Can you share the url to download the battery patch for KK. Btw, what is the FW version after the battery patch? Currently, my FW version is 2.19.40.18_20141003_8008
My zf5 has this problem. For no reason the phone will be hot n batt drain fast. I can feel e heat as it is in my pocket.
url? just do system update... if got new one u will be prompted to install...
well my software information is:
baseband: 1434_1.4.39.2_0922
kernel: 3.10.20-262908-g3ebb293
build number: 2.19.40.18_20141003_8008
get the latest firmware (if u have not done so...) ...
regards,
wacky
Not sure if anyone encounter. My zf5 will kok up if i use dual sim. Was using my office sim with personal sim.
Initially, everthing is fine so happy. But soon my personal sim will lose signal and not working at all. Do so much setting and even check with my ISP SH. My sim is working n nothing wrong.
Since that few days of problem solving i stop using my dual sim simultaneously.
Very dissappointed.
Hi, for me no issue using both sim even after upgrade to kitkat, in fact, battery life about the same, only thing is my installed app no longer able to write to sdcard due to google's policy.
Any idea how to remove the slide to unlock when you power yr phone from standby mode... no such issue b4 update to kk..
gps indeed quite weak for this phone. i use sgbus also got problem.
screen brightness also another issue. dim not dim, bright not bright.
battery jiak damn fast also.
but still this phone is one of the best in the price range.
totally not working... updated the messaging app today... my OTPs are still being blocked... no difference watsoever...i also disabled unknown call blocking liao... no idea where else is there where by can seperately control SMS blocking (if this even exists) ...
regards,
wacky
Agreed even after e last firmware upgrade the battery life is still battery.
Still the phone heat up even when screen is off.
New update to the messaging app to solve this issue. Try it?Encountered same issue as you yesterday while purchase item online and never receive any SMS for OTP. Later found it at the blocked folder.
Wouldn't actually recommend the LTE version due to the fact that it has the same battery capacity as the 3G version.Is this phone still worth a buy ? I m pretty interested in the 16G LTE version. Any recommendation ?
My zenfone 5 has already updated to the latest firmware and still encounter same issue. Look like kitkat is not as stable.
After unmount external OTG, the app installed in SD cannot open. Need to un-mount and re-mount SD to work.
