derrickgoh
- Jan 1, 2000
Was so easy on android. How do i type in chinese via pinyin on iOS 8.0.2?
Ok found it under general settings.
but seems we can select 'vowel'![]()
I mean pinyin got 4 vowels, we can choose which vowel
Will be much faster if can shortlist by entering the tones but I don't think its possible. No choice lor have to search one by one.
This one no one can help you liao. Try Google Translate then cut & paste.But at times when our Chinese is weak, u type 'xy' aka xu yao, 须要 & 需要 appears.. Dunno which to use
Or get some hot Beijing babe to tutor you. 我爱华语
Couldn't use wahy had to type the full thing 好麻烦 can thou with hmf
