iPhone 6/6+ Screen Protectors
galliano
Also not sure is it just my observation or fact?!?!
Aloe of ppl here just blindly follow what ppl say or recommended without knowing what they paying for or buying??
There a lot more than just look to the accessories for devices nowadays if not why so many brand are spending and will to spend into researching into different materials or design.
The accessories market for phones is huge.
frizee
striker22
I personally think the horseshoe design works great with the touch ID home bottom. Previous renditions of past iphones that cover everything always include that gimmicky home button sticker to raise it slightly from the thicker glass protector until the 5s touch ID made that redundant but harder to press.
hawkz02
Try PSAJ luh. Haha or best, naked!
Update update
Those thinking of using psaj with bse can forget it. Using the Matt rear and tried to put on psaj clear. The friction was so great between the two that I cannot even put in the case.
Not the thickness but the friction so dun even think of getting it our after u even manage to force in.
Not sure of healing shield material. Anyone using with healing shield can comment on this?? If compatible then I will switch to healing shield even it mean less protection but I do not want to waste my psaj.
If also cannot then will be letting go of mine psajs.
Tried with spigen ultra hybrid also the thickness is forcing a small gap along the edge that exposed a very small part of the aluminum body.
So far successful with aluminum bumpers and the cheapo ip5/5s leather case lookalike
