iPhone 6/6+ Screen Protectors
hawkz02
I personally think the horseshoe design works great with the touch ID home bottom. Previous renditions of past iphones that cover everything always include that gimmicky home button sticker to raise it slightly from the thicker glass protector until the 5s touch ID made that redundant but harder to press.
Agreed. Horseshoe design work better and especially now the glass is still thick at 0.3mm.
ragnarok95
Senior Moderator
Senior Moderator
Psaj clear with Apple stock back protector. No issue fitting. Removing also not an issue.
laughingPANDA
Update update
Those thinking of using psaj with bse can forget it. Using the Matt rear and tried to put on psaj clear. The friction was so great between the two that I cannot even put in the case.
Not the thickness but the friction so dun even think of getting it our after u even manage to force in.
Not sure of healing shield material. Anyone using with healing shield can comment on this?? If compatible then I will switch to healing shield even it mean less protection but I do not want to waste my psaj.
If also cannot then will be letting go of mine psajs.
Tried with spigen ultra hybrid also the thickness is forcing a small gap along the edge that exposed a very small part of the aluminum body.
So far successful with aluminum bumpers and the cheapo ip5/5s leather case lookalike
Using with healing shield no issue :)
thenakedshades
Anybody want? Pm me quick! iPhone 6 black
nethdale
Hi,
i understand this link is for the 0.15mm. If im not wrong there are 3 heights right? 0.3, 0.2 and 0.15. Is this the correct link for the 0.2mm? http://detail.tmall.com/item.htm?sp...scm=1003.1.03054.ITEM_41213660085_65793&pos=1
All three sizes are full protection of the screen right?
Also i noticed that the ones they sell on ebay have color: black and white. However on tian mao i cant seem to select the color. May i know if there is a clear option? I dont really like the color. Thanks a ton for answering my questions!
darkbladez
New colour out for iPhone 6? Heh...or do you mean space grey?
You may have a better chance of selling it at Marketplace forum.
The black means Black border around it. Go read more on full size tempered glass protector for iPhone 6 and you will understand it.
