[Software Update] iOS 8.1 Discussions
arcturuz
noticed a couple of things after updating
1) got back around 2gb of space after update
2) touch id failure rate has improved
poloeric_2000
thanks man. so surfing experience is better and overall performance has improved?
Absolutely!
Give it a try!
I go for the updates because IOS 8.02 make me haywire!
Been doing hard reset a few times... End up throw my iPad 3 on the sofa...
My 6 years old daughter also play until pek cek, lol.
So without hesitation, once it's relase.. I launch the upgrade to iOS 8.1
testing1234
Absolutely!
Give it a try!
good to know. dont know why ipad 3 restarted 3 times on its own while i was on safari last night! will just do that. thanks again
poloeric_2000
Overall, those who visited this site is to get more information before decide to launch the official update to ios8.1
Conclusion: Lauch ASAP!
Cheers
Ev0d3vil
Restored my iPad to factory. Seems like safari only saves passwords for certain websites.. Hwz not included..
cherryboom
updated early morning using OTA. so far so good on M1. pretty pretty no run water
radzkal
Tried Movie Box after the update. It doesn't work anymore.
OH NOOOOOOOO.
anyway did u try changing the date to maybe 16 sept 2014 n then try launching it before changing back to current date? i havent updated yet n dont intend to either until this is fixed i guess?
ralliart12
Haven't tried yet - but hoping they'll fix an irritating cut/copy/paste bug. Back in iOS 8, sometimes no matter how many times I re-highlight the sentence the options will just disappear in a flash.
I'd experienced this in Evernote; but somehow I think it's an app-specific issue.
chris888222
It always happens to me on Safari. Notes occasionally as well. Don't think its app specific, more like OS bug.
Now I trying in this text field. Still ok.
ray7188
Check with you guys anyone did a upgrade from 8.0 direct to 8.1 via OTA or iTunes? Checked a few time but keep getting 8.0.2 instead
ray7188
Tried the method stated adove but still can't get it keep getting 8.0.2 . Hmm maybe will give it another try later
gardiboy
Force close the settings app and go in again to check?
How about plugging to iTunes to check?
Have you declined any updates previously?
Check under usage / storage, see if any old updates are dumped there?
