[Software Update] iOS 8.1 Discussions
abcwarrior
Changing cellular band from 3G to 4G takes much longer now, roughly 1 minute. For iOS 8.0 and 8.0.2, 4G gets locked on almost instantaneously.
Otherwise, WiFi is faster now and more stable. How's battery life for you guys?
ragnarok95
Senior Moderator
Senior Moderator
For me... if its a 8.X.X update, then yes, if it's ain't broken, don't fix it.
But if it's a 8.X update... i rather update.
:crazy:
For me la... :crazy:
s0nics0nic
seems like we're getting mixed reviews leh! haha some say very good, better than 8.0.1 or 8.0.2.. some say worse o.o
b00mxer
Like me I thought everything was perfect.. But only for the start lol... After awhile the problems arise
Thoma5
Anyone hasconfirmed that the safari spinning wheel bug has been fixed?
still got even after updating but then still better then ios 8.02...
Previously very drain battery sia usin safari...chrome browser still better then safari for ios 8...
tohchr
Those having battery drain, did u enabled icloud photo beta? That option keep uploading in the background even when screen is off. I off the icloud photo beta, everything good to go. Battery life is as good as on 8.0.2
layzibum22
Can I confirm did anyone went with this route?
Existing ipad/iphone on ios 7.1.2... did full backup
Use this full backup to restore to NEW ipad/iphone that is on ios 8.1.
I believe it is possible but would like check if anyone successfully upgrade their device through this way. Thank you!
No one went this way?
s0nics0nic
this icloud photo beta is only available on 8.1?
chris888222
Brought the phone out (went to alab to replace my f-ed up lightning cable) and checked the battery life. Non stop use for the 3 hours to-and-fro battery life from 100% down to 44%.
Feels about the same as 8.0.2.
*adiBOY
I have turned off iCloud Beta right from the start but I still feel the battery life not as tong as 8.0.2.
