either convenient pack (aka wet wipe version) or dropper version. no spray version for plus.
Wouldn't the alcohol in the wipes remove the oleophobic coating on the iPhone screen? I feel like trying too..
u never read the instruction 1 ah? wet wipe got alcohol lei.
non plus version u just need to spray on the microfibre cloth and wipe it in one direction, avoiding circular motions.
i'm not going for the non plus version liao since they have improved version which claims to last 12 mths.
according to the seller, the plus version doesn't have spray bottle becos it will crystalised so left for some time.
tried like about 6-7 times liao..
still able to stick back..
tried the matte healing shield surface n i didnt like the finish. anyway i got one back matte piece left. pm me if u are interested. pardon me, mods.
What's the coverage? And thickness? If too thick can't fit into psaj.Guys,
How about the idea of glass protector for your iphone6 back? Any takers? I might be importing if the response is good.
Cheers
Will be better if you bring in matte back protector, something like BSE version but thinner
Glass back SP confirm thick one. Normal front glass SP alr so thick.
seems like using film sp is still the way to go...use glass got so many considerations aka headache
why paste back protector
Not true.
Front got 1mm thickness one but easily will have hairline crack due to pressure during usage. If u not hoping for full front coverage there many option ranging from 0.1mm to common 0.2mm to 0.4mm which ppl shun
BTW the rear even got also cover only the center like normal protector. Will will not fit the contour of iPhone
wa lan eh this imos glass price can fight with 'the best' ITG sia..
imos Solid EX Corning for iPhone 6 Plus
