iPad Air 2 Screen issues
shadez9
Not sure if anybody has this issue on their set. A slight pressure on the back of the Air 2 brings about a wave effect on the screen similar to that if you were to press on the screen with your finger. Is that normal. Don't have this problem on my original air :vijayadmin:
Crimsom
For air 2 owners, is this a very serious issue? Does using a case solve the problem?
Was about to purchase from online apple store until i read about this screen distortion problem.
Godbleseu
Mine have the same issue as TS.
I need to press harder to see that effect...light touch will not cause this.
Opachu
u really need to press quite hard for this distortion to show up. at least for me. normal usage with just holding the back of the iPad is fine
a562140
went overboard with thin it seems. i think they to have more structural engineers on board to complement the designers.
addictzz
I think if using a case "solve" the problem, that is not really called solving. That's covering.
Some said that it doesnt really happen if u dont press hardly. Maybe some people hold their ipad in one hand tensely. Thumbs at the front and four fingers at the back thus creating a tension that presses out the screen from behind with the 4 fingers. That's why the problem happens.
SimonLam
Moderator
Moderator
All LCD also the same mah..u try poking hard into your IPS or LED monitor u see similar result.
The key question is do you normally poke so hard at a screen?
Tempered glass help?
VodkaPear
went to test test the screen at istudio.
actually must press quite hard to get that effect.
who the hell will use so much str for each tap, fingers will be damn tired lo.
and there is a iPad air1 jus beside the air2. actually if use same force on the screen, also have the same effect.
StanII
Must really exert alot of pressure using your fingers then can see it and it's only one spot just below the middle towards the right.
Suspect where that's the logic board, no battery as a shield.
shadez9
I went to try in nubox as well. Must press quite hard before it shows. Mine must a a dud set since normal grip or lifting the iPad Air 2 up from the right side also shows the distortion.
EldonChew
The issue is not with poking/pressing the screen too hard..
It is if you hold the iPad with one thumb on the right bezel and 4 fingers behind the iPad and just simply lifting it up, it bends the component inside or something
attachment.php
http://forums.macrumors.com/showthread.php?t=1808921
StanII
Well.. from that picture that's like lifting the iPad with only it's weight so probably a defective one.
So far only that spot will show that distortion. Suspect that's where the logic board is. Tried on the left side, no such screen issue.
