iPhone 6 PLUS Cases (NO SALES)
jslim2
Thought I'd share some pictures of my casing now with regards to the yellowing part (been using it since I received it on 14 Oct), casing is still clear. Other casing I got on 19 Sept was already yellow as heck even before I got my Ringke.
Edit: Bro freedomczh I tried to simulate sweaty palms by washing my hands and gripping the case with my phone, for the sides it's ok, not much slipping but I can feel the slip if I rest the back of the casing on my palm. Hope it helps.
laughingPANDA
Does it add a lot of bulk to the phone like the capsule of spigen?
jslim2
Not really leh, it's comparable to holding the phone without a casing, just slightly thicker. For me I think the grip is just nice for my hand, not too big or too small.
Weight wise I can't feel the difference, so I'm guessing the bulk from the casing should be quite insignificant.
porcu
Best slim case has to be power support. Issue is only that it's harder to remove as it is tight.
ecneret_eel
anyway I realised that there is a convenient way to test for yellowing.
turn off the lights and turn on your torch function..
my capsule looks yellow man
ekardo
rinse makes the phone rock when put on table right? because it didn't flush with the protruding len...
jslim2
Anyone know how much is Rinke Fusion clear for iPhone 6 plus?
Around $19 inc shipping now (USD just grew stronger recently zz).
Edit: If you're planning to order online take note of the delivery delays. Ordered a second batch with my friends from Rearth online store yesterday, estimated shipping date is 18-28 November so note the delay. If you're in a rush to get it then it might be more worth it to buy locally.
evewbb
quick question - I've applied a back protector for my iphone 6+ - will the Rinke casing still fit w/o destroying the back protector?
TIA!
muddle
From the pictures and comments from the poster, already obvious the rear cutout is taller than the lens. So no it wont rock.
wakakakaka
Anybody ordering rearth ringke online? Thinking of getting 1 but retail prices too ex IMO.
Gonna use tough armour mint for now :) where's the best place to get it other than p2o? A bit out of the way to travel there. Will challenger be cheaper? TIA! :D
athenodorus
TIA!
should be fine with most cases la..
unless it's PSAJ (not sure if it fits)..if it fits, every other cases will fit.
MeRfMeRf
this Ringke case sounds too good to be true, wait till my spigen capsule chui or turn yellowy then hoot.
Shutterfly
I just ordered one from eBay. Delivery date is from 14 Nov to 01 Dec.
