The Nexus 5 Thread
kennyboy
looks like mx player cant used.. i think i will wait for OTA instead and meanwhile wait for mx player to be updated.. lazy to reinstall everything.
MX player got beta version that works if u can't wait.
kEvinErd
Mmm can't seem to feel any improvement in battery after updating to Lollipop..
How is your battery experience like?
jtec14
Flashing of L was fast and easy but having problems with CWM recovery and SuperSU(SU binary not installed). Googled and seems like SuperSU got issues? anyone facing the same?
Ended flashing back kitkat first :(
radon
kifo
I had lots of problem directly installing over my 4.4.4. In the end, I wiped everything and went with a clean install. It is finally working flawless now.
Rooted and supersu all working.
jtec14
Oh, I also did not wipe out for my problematic upgrade last night... think last alternative clean upgrade. Can I check what version of recovery and supersu u flashed? Thanks
batboyz
Couldn't wait for OTA, so decided to sideload. Now optimising apps... :s12:
Done...
Now waiting for OTA image for N7 to sideload...
Exp so far, feel not as smooth and fluid as on KitKat... Sad...
Much better now after settled down.
ah_cleo
couldnt wait and decided to flash the factory image. pls note that it wipes data..
i follow instruction from here.
https://developers.google.com/android/nexus/images
How to: Flash Nexus 5 Factory Images | Droid Life
Running Into The Dreaded "missing system.img" Error Flashing Android 5.0 Factory Images? Here's How To Get Around It
**edited**
anyonw using 16gb has flashed factory image and wipe the phone fully? pls let me know ur stock total space. mine is 12.5gb.. not sure if it is correct or wrong.
kEvinErd
**edited**
Seems correct. No issues no need to worry
