Official ZenFone 5 Thread
botoguy
why they don't want use intel liao?
intel mobilechip just come out not long only and now intel no more do mobilechip for mobile anymore???
blade007
Most likely intel chip don't support 4G?
Sent from GAGT Android App
botoguy
wah... erm.. intel for lte is in progress for not going to make improvement to lte le?
xtemujin
Both slots are 3G enabled but at any one time only one sim will be 3G and the other 2G at dual sim standby.
SIM1: 3G SIM2: 2G
SIM1: 2G SIM2: 3G
for the dualsim, is it both also 3G or only 1 of the slot is 3G?
creative11112004
Did anyone encounter on errors on the dual sim zf5, when either 1 of the sim on 3g mode, it will disconnect and reconnect back again?I got this error lots of times already, changed both sim card from telco already still the same.
wackykid
SIM1: 3G SIM2: 2G
SIM1: 2G SIM2: 3G
actually i'll say only 1 SIM will have the data enabled... so effectively i wouldn't say that the other SIM is 2G... since 2G naturally would refer to the data speed..
so both SIMs are 3G enabled... which ever SIM u set as the data carrier will be operating at 3G speeds... no need to physically swap out the card...
regards,
wacky
africatwin
I have many error from using zf5 with 2 sim enable. Since then.stop using it as dual sim phone
Chisel
At Taoyuan airport now.
NT4740 (tax free) for ZF5 3G (16GB).
NT7100 (tax free) for ZF5 LTE (32GB).
zook09
ask u...is the zenfone root apk still working to root this phone ?
or it depends on what SW and android version u have ?
i am thinking of getting either this dual sim version or its LTE version.
but very few links about rooting the LTE version.
also saw somewhere got "official" rooting app from Asus !? true or not ?
Gundam_seed
My zenfone 5 always hang ; ( and vibrate.
Bought from bedok mall m1 . Is tat distributer only ah? So service is go asus instead??or the shop
botoguy
from what my friend told me using asus de, need to go the asus service centre then can... wah.. zenfone5 latest firmware got many problems ar... was about to buy then in the end, decided to buy iphone 6 plus.
blurwulf
Any problem with your handset you take it to the maker's service center.
Be ready to tahan the long q...
dsearch4et
Contest!
For Zenfone owners, this should be interesting!!!
https://www.facebook.com/asus.sg/ph...3663889667628/880837738616902/?type=1&theater
blurwulf
Just realsied tat i can't send voice msg via WeChat on my ZF5 (non-LTE). Hold the talk button and talk but then it just won't send the msg (no error whatsoever).
BTW, I can record my voice on the phone using other app no problem, so doesn't look like microphone faulty.
Anyone has the same problem?
africatwin
I have used the hold n talk function on wechat. No problem
