Below are some of the pictures on Adix82 full privacy tempered glass on Apple leather case. PSAJ shouldn't have any problem fitting it as it can fit on Apple leather case alrdy.
Any idea how thick is it ?
where to buy![]()
Does he have a one without the privacy? ? Meaning normal tempered glass
TG can protect the screen from being cracked thought it is thicker than a normal SP but nowadays TG getting more and more thinner liao. at first come out, i damm DL... will affect the sensitivity de...
UAG case tested. No problem at all.
Do it have the plus version?? Or onli 4.7
Finger print resistant level is high. Monday I try on psaj
Bro.. I feel like crying when I see what u wrote.. Thank you so much..
Everyone tot I use air to protect my hand phone.. No need use case.. No need use protector.. Just air will do..
It always come in 6 plus and 6 version. For your info only, no selling in this thread.
Anyone can advise where can buy the moshi ivisor glass for ip 6 plus
westgate nubox
Nubox only has the Moshi AG plastic sp version and not the iVisor Glass.westgate nubox
so what casing can you put when you stick that full edge glass screen protector on??
