magix
- May 28, 2000
andr3wyong thanks for the quick respond. What the email address to sent? Don't think is NOC@viewqwest.com (that the only email address i can remember)Just sign up for the promotional plan as per normal, use the same info and if you are emailing in just note that you are doing a recontract.
Any bundled router/TV will be couriered to you.
HTH
