The Watch Thread - Part 6
Henabi
It's been a while since "watch in car" photos!
Chilling in the car...
Pam 351 with one of my most comfortable and versatile straps, dark blue with cognac brown keepers. :)
When wanna let us morest your pam. Your straps and your AMG?!?!
Lezzare
Getting car serviced and changing brake pads. On rainy days like these, brakes are very important.
RyanGiggs11
Woah... something really different, almost like mixing Asian & Western influences together.
Well, the closest that you will get will be this
22mm Brushed Fu
Or you can speak with Blackforest and see if you can commission 1x 22mm "Fu" buckle, if you really want one!
Hi Azrielsc,
Will it be too weird if i commission a strap thats 22x24?
Normally people will make a strap thats 22mm at the buckle and 24mm at the lugs (for tapered straps). But if I make a strap thats 24mm at the buckle and 22mm at the lugs, will it be too weird?
Thanks.
@Hua_Hui , That red strap I posted was acquired about 2 months back and I've used it for about 20 times or so. I would have to say the quality is not bad and the strap is thick and comfortable.
@Azrielsc , Yeah they do have quite a range of colours for their Alligator straps which got me interested and not forgetting the buckles too. Btw, if you decide to get something from them, you can use the 20% discount code: BF20XMAS
Hi, the promo code has ended? I tried but not successful...
Thanks.
Lezzare
They removed your engine block to change brake pads?! :eek: :D
The workshop thought I wanna improve engine brake :s22:
How is ur dietrich so far? I tried it and thought the case finishing quite well made...
I like it. I've got 2 SevenFridays, and I feel that the Dietrich is better quality. Its got Sapphire crystal too, unlike Mineral Crystal on SevenFriday.
