iPhone 6/6+ Screen Protectors
ProGamer84
Anyone using ITG temper glass? which the newer want, can cover up all the whole edge of the iphone 6 plus.
fuzzybear
Good choice been using it for abt a month and no oily prints :) use at night also eyes not pain :) best of all less than 10bux...those who really spent more than $20-30 on a sp really robert big time
from adix?
how thick?
|XcElLeNcE|
Do not go for the ITG Max TG which covers the whole screen. Its a dust magnet. The edges of the TG has tiny gaps which dust will trap underneath the silicone edge.
lee-turbo
i think this is the best, imos Solid EX Corning
http://moscoat.pixnet.net/blog/post/188115237
Latest Case Compatibility of imos Solid EX 3D Corning Gorilla Glass Screen Protector for iPhone 6/6 Plus.
Apple Leather Case
Apple Silicone Case
Innerexile Hydra Case
Spigen Ultra Hybrid
Spigen Ultra Capsule
Rearth Rinke Max
Rearth Rinke Fusion
Nillkin Victoria Leather Case
Nillkin Nature 0.6mm TPU Case
Totu Design Touch Series
Viva Madrid Flip Series
Power Support Air Jacket
more to come...
chercm
any reviews on Spigen iPhone 6 Plus Screen Protector Steinheil Flex HD and iPhone 6 Plus Screen Protector GLAS.tR SLIM?
is it worth while in getting it or any screen protectors to recommend for iPhone 6 plus ?
anyone can advice please ?
chercm
so many pages . anyone can advice which screen protector cover to the edges of the iPhone 6 + ?
VoodooEx
Not recommended to buy. Weak edges that chipped off easily. TG edge is also a dust magnet.
?????-imos???iPhone 6 /6 Plus ?? 3D ????(??)????? (Corning) @ ???? ?? ??? ?? :: ??? PIXNET ::
Apple Leather Case
Apple Silicone Case
Spigen Ultra Hybrid
Rearth Rinke Max
Rearth Rinke Fusion
more to come...
Waiting for this man...
ProGamer84
ok thanks noted..
noted. but now no good temper glass to buy..
fuzzybear
What glue issue? Anyone got a tempered on 6 plus with no micro bubbles at the sides? Thx
The store told me is glue Issue got some bubbles things ok the edge and on the home button area
So I reject it and go for normal sp first
freedomczh
its the glue issue lor
i rejected one before
at a shop and use a normal SP for now
until i can find a bettter glass SP
I also using comma clear, have to agreed that it is the glue issue. But it is really quite fingerprint resistant and smooth overall. Currently using it till a better glass comes along.
chercm
no go for spigen that glass..now there are better fitting glass in the market already~
any recommendation please ?
what about this ?iPhone 6 Plus Screen Protector Steinheil Flex HD? is it from edge to edge ?
thenakedshades
Anyone still using Mobilelite(Jimmy) glass protector? Is it really oil and finger resistance? After using for long I mean
fuzzybear
Seem like no much good gala sp around go invest
athenodorus
I dun think so. Not really good if I remembered correctly from some bros here who have it.
You can try the imos film type sp..do a search in this thread u should find info on that.
