Ask a Bicycle Question - Part 5
I'mknotdumb!
Hi edmwer i'm using crankset Shimano T551, 26/36/48 but the teeth like not straight if i want to replace it what size can i choose? issit must be 26/36/48 :s11:
SmilingDevil
You can change to any size you want. Single speed or double speed also can. Just need to change your chain length.
Sadisticnoob
Can choose any side if u need funny sizes need to custom make
Citiguy
Hello everyone,
I have a query about floor pumps. My pump does not pump for the first few strokes. The first few strokes are very light, with no resistance at all. Only after a few strokes, that the pump begin to push air into the tube. Is this a sign of pump failure?
TIA for replies. :)
SmilingDevil
Hello everyone,
TIA for replies. :)
Wah you disappear so long! Does it have double valve head?
ninja99
Hi SD, I see that you have ridgeback hybrid offering in your shop, can share price and model? I'm looking for hybrid for cummuter.
Sadisticnoob
Hello everyone,
TIA for replies. :)
Pressure =force/area
As long as still can press down its fine
SmilingDevil
I using similar pump by lezyne haha.
My only issue when i pump my RB is that i need to release some air from my tubes before i pump.
Yes, so do I!
Normal lah. 2 reasons for it.
1) Presta valve maybe stuck, so by releasing the air, you are also "releasing" the valve.
2) Pressure in the tube is high, you will need to use a higher pressure from the pump to force open the valve to pump. Shd see how my guys who are 60 kg need to jump on the pump to get the air in:s13:
So, by releasing air, its much easier to pump.
Pm u later.
patcheon
I need to let go all the air from the rear wheel of my roadbike in order to get air going in. Non of my other wheels needs to do this including the front wheel of the same road bike. :s22::s22::s11:
hellhole
anyone has any opion on the bottecchia 8avio? thinking of getting one.. not sure how much it will set me back...
want to use it for some training for tri races... amature of course :)
