Stereo Promotion!!
icecapt
Hi, just want to check if it's possible to reshell hybrid iems with UM (specifically the dunu dn2000). I do understand from other people that there might be some risks involved if it can be done. Also, does the reshell price include the ear impression cost? thanks :)
TeamStereo
Suspended
We will help you check with UM bro if they are able to reshell this IEM, they can only revert on weekdays. Reshell costs $300/pair excluding ear impressions. You might want to check Digisound at Novena Square for that. :)
TeamStereo
Suspended
Ho! Ho! Ho! Merry Christmas!!!
Your promotion wishlist is up on first page of Stereo Promotion!
:D :s12:
TeamStereo
Suspended
Bro, your Dunu DN2000 cannot be reshelled after we've checked with UM. Sorry about that.
jl255
Can you recommend a good earphone with following criteria:
- wide soundstage
- good bass
- <$150
I tried the t-jays four and really liked it and wondering about similar alternatives. Tks.
TeamStereo
Suspended
- wide soundstage
- good bass
- <$150
Have you tried the Fischer Audio Bullet, the new model from Sennheiser - CX 3.00? And if you can extend the budget a bit, one of the great options would be the JVC FXT208SE. This model also comes with 10% off discount.
The rest of the promotion list can be viewed on first page of Stereo Promotion. ;)
john doe 84
Dear Stereo,
What are the T&C to enjoy the promo?
I'm interested in buying the HDVA 600 using the Citibank credit card installment plan
TeamStereo
Suspended
Dear Stereo,
Hi bro! You can use Citibank credit card for 0% interest free instalment plan for every purchase of $500 and above in a single receipt. You will also get a FREE AKG K550 (worth $339.90) as part of this month's promotion for every purchase of Sennheiser HDVA600.
You can head down to either of our stores to process the order and payment as well as to clarify other queries. :)
TeamStereo
Suspended
Hi, does the Apuresound cable come with balanced 4 pin option?
This month (some) promo bundled with Apuresound... Hmmm... any reason why Apuresound? :D
Should bundle with CH800S (for the HD800)! =:p
Hi bros! No balanced cable for Sennheiser HD800 and AKG K712 Pro.
The bundle deals are decided by Stereo Management and every month's promotion is different.
pyu
Hi,
I visited Stereo at Plaza Singapura in November and was disappointed to find that the HD800 was out of stock and I left my contact details with your staff. I notice that there is still a HD800 promotion in December - do you still have it in stock?
TeamStereo
Suspended
Hi,
Hi there! We are expecting the stocks to arrive within this month. If you are keen you can consider to do a pre-order and we can immediately reserve a set for you. :)
ochibi89
will you recommend Audio-Technica ATH-M50x headphones for an entry level Hi-Res music listening? couple with filo X1..
