320L can support sata 3?
or only sata 2 according to online specs?
Sata-3 (6 Gbps) is supported. Check the HDD compatibility list for more info.
Saw your PM regarding this problem. Unfortunately, I don't own this NAS model (my is DNS-320). Have you try redoing the UPnP AV Server by first deleting the shares setting and adding it back again. I assumed this is the same apps used in DNS-320L.
hmm bro, it doesn't work for me. Ive' tried to change all diff versions of firmware, remove the folder and add back, and factory reset. All did not work for me.
I read about fun plug. and minidlna or twonky.. are they easy to install? and by installing, does it affect the stock application?
I found out something disturbing after i upgraded to firmware 2.05 on my DNS-320. Now that we are using EXT4 file system, i found that it's eating up a lot of space.
Just an illustration, my files are as below:
Size on disk : 23.5GB
Contains : 16,944 Files, 202 Folders.
By have the same set of files in my Windows Hard drive it's very near to 9.54 GB (size on disk) but on the NAS now it's 23.5 GB.
Anything that we can do to remove this issue so that we can use more space ?
I think EXT3 is better in this area.
Thanks.
Thanks.
selling a hardly used dns320l in box for only $70. let me know if you are keen
AFAIK, this model use EXT4 FS from the start.
As for the increased in the space usage, have you check it's not due to deleted files stored in NAS recycled bin folder?
Hi Albert,
I found this problem previously, so I kinda reformat the whole NAS with 2 drives and it is found to be the same.
I use the Properties of the folder to check the information that i've provided. So I assume, this would not relate to Recycle bin. I'm only checking on that particular folder.
I counter check with another DNS-320L and they are showing the same thing![]()
Can you do a du -s on that folder and post the result here?
I'm not familiar with Linux interface. I'm using Windows to get the folder properties. Maybe you could try on your side checking on the size of a large folder to see if the size and size on disk are they very different?
I noticed that if I have small files of large quantities, it became worse. If only 1 single file of 9gb, it's ok
Paragon ExtFS for Windows Free For personal use only
Paragon ExtFS for Windows is a special utility which allows you to get full access to Ext2 / Ext3 / Ext4 in Windows. With Paragon Ext for Windows, you can work with a Linux native file system using Windows. Just plug in your hard disk with Ext2/3/4 partitions to your PC and you can instantly modify files on Linux partition.'
Ext for Windows | PARAGON Software Group - Ext2 / Ext3 / Ext4 for Windows 7 8 xp
Ext2Fsd Project
Ext2Fsd Project
Unfortunately I don't own this model, the DNS-320 uses EXT3 FS. And yes, I have already checked and the result is about the same as shown on Windows properties.
Which is why I suggest using the Disk Usage command on Linux to calculate the actual disk storage used as Windows might give the wrong result depending on the default cluster used during formatting.
