Ask a Bicycle Question - Part 5
de5ert
Hi, any recommendation for an entry level wireless computer? basically just want to see the distance travelled and avg speed etc.
Cateye wireless cadence computer is ok imo.
otherwise any non branded works too. I have got a fren who has a wireless cadence computer for 30 bucks.has back light too.
Sadisticnoob
hi quick shoutout for those who wanna ride tmr.
3x seletar loop tmr just wa me if wanna come
g_t2006
Any recommendations for a foldable touring bicycle for a female? Have not done much research yet. Am just looking at Bike Friday and Tern. Open to more suggestions. Budget say up to $4k. Or should I just get her a durable road bicycle?
MIVEC525
Brompton?:):s22::D
Sadisticnoob
depends on how much space you have, a foldable occupy much less space
wackymaus75
you what name. :eek:
Is my chain too long?
its not even on a crank?
Sadisticnoob
Space and time taken to set if up/fold it are the least concern.
Main concerns are comfort, ease of getting parts and reliability.
maybe can get a surly long haul trucker
Long Haul Trucker | Bikes | Surly Bikes
its a custom frame there is no "stock" setting avaliable so you can kinda specify what you wanna get.
they have the fatter 26" if you need to take up more weight or the skinner 700c (28" equivalent) which enables you to go faster.
much easier to get parts too since there's a huge availability of wheels. tire choices and either mtb or road drive train. Can get hollow tech 2 crank , for easy removal/installation.
IronMac
Folding touring bike and road bike are two different things.
What ere her needs, exactly?
IronMac
Then, get a custom touring bike from Thorn Cycles, Rodriguez, True North, Co-Motion, Honey Bikes, etc. Get it built with a Rohloff hub and Gates drivetrain.
Since she is a female, she will most likely best fit with 26-inch wheels.
Consider having it built with SS couplers along with a special suitcase for a broken-down bike.
The above will blow your 4K budget but what the hey. :s22:
If you want to talk more, PM me, I used to do solo, self-supported touring. Been through over a dozen countries.
patcheon
Brought this....but dunno which of my bikes is suitable to put it on. :s22:=:p
Sadisticnoob
wind at coastal today is ******* strong.
ave 7kts, wind gusts of 17kts :( almost got blown off the bike
