LG G3
doki81
Seem like Androidnow 8.0 is taken off from XDA. No more future updates...:(
lastest update is 8.2 SE :) you try google and you will see a Polish forum that S3V3N original from....he is updating there..
i have updated to 8.2 SE but there is something i dont like..
jeffprobst
Wah really man. Update to lollipopbatt drain faster.
Update and factory reset already.
multi
Hi doki81,
Possible to share the 8.2 rom link? I'm lost at the poland forum...:s22:
BlueSwift
After 3 days of use with Lollipop, so far so good for me.... Only after factory reset. Love the smooth animations and the other 5.0 features. Goes well with my moto 360 with some small minute stuff which does not have when using kitkat. Battery life still the same though. And bragging rights compared to HTC, Sony and Samsung users.
doki81
Bro your inbox is full...can't reply you there.
So the center clock is a eye sore, anyway to remove or move back to default?
not yet have any solution..but s3v3n should be working on something after i reported this issue to him at the Polish forum.. :)
boboto
Hi,
After updating my lg g3 to the latest version, I always have an error message saying 'call has stopped' and my contacts couldn't load and my battery drain alot faster. Anyone can help?
Thanks.
hermes76
Hi,
Thanks.
initially i had a "Home has stopped" error but now seems ok liao. however i feel that this Lollipop is a ram eater..
samson1
There was some mention there is a memory leak bug that eats up the ram. But in general, without the bug happening, I feel the RAM consumed is the same or less.
colonelsoh
Eh now cannot screenshot by holding the home button alr ah??
I mean the quick memo part
colonelsoh
Knn the whatsapp keep popping out even when I off notifications...
Line and the rest of the app no problem
BlueSwift
Those who did the LG backup to their phones and then factory reset after upgrading to lollipop having any issues? None for me so far and im liking it. And if the rest are not facing any issues, this is a viable method (but abit time consuming cuz also have to manually backup other apps like whatsapp, facer, line, etc.).
How much ram do u all usually have left with the memory bug? I usually have 1.2GB of free ram.
