Audio Technica Appreciation Thread
TeamStereo
Suspended
Time to sweat off those calories from the holiday festivities and be inspired to work out with the latest Audio Technica Sonic Sport In-Ears. Choose the one that will best suit your active lifestyle and make that new year’s body resolution happen!
edwinz
I'm thinking of organizing a work trip to Japan sometime later this year to meet clients, can take the chance to make some hoots too heh heh :D
Who knows what new products will come out by then.
Akiba yodabashi for 2-4 sets left when I was there... good luck! hope still got stock...
Funny that CKR9 is now discounted for online store.
http://www.yodobashi.com/audio-technica-%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%86%E3%82%AF%E3%83%8B%E3%82%AB-ATH-CKR10-%E3%82%A4%E3%83%B3%E3%83%8A%E3%83%BC%E3%82%A4%E3%83%A4%E3%83%BC%E3%83%98%E3%83%83%E3%83%89%E3%83%9B%E3%83%B3-%E3%83%8F%E3%82%A4%E3%83%AC%E3%82%BE%E9%9F%B3%E6%BA%90%E5%AF%BE%E5%BF%9C/pd/100000001002178006/
xuan87
Haha! No lah, I won't be aiming for the CKR10 since I already have my Dita Answer. Might hoot a AK100II if the price turns out to be attractive.
Also interested in testing the entire Ocharaku range.
BlurKillerEX
Guys, I've been using the ath m50x for some time now, the ear cups have quite a bit of wear and tear to it. Is it possible to replace it? Been searching online on how to replace but only found one video for m50 not the m50x, is the process the same?
Also, which ear cups are recommended?
Anyone? Looking for replacement earpads
edwinz
maybe use the same website to get an feeling of discounts possible and pay with visa an bring passport! :D
TeamStereo
Suspended
Instant Outfit-Of-The-Day! Complete your day with a music and headphones that perfectly match your fashion style. Our customer is wearing the coolest Audio Technica ATH-FW55 furry headphones.
#OOTD #audiotechnica #stereoelectronics
feralslash
Need some help peeps.
I am using Illegear RE-15, which is basically same as Aftershock XG-15.
With the ATH-IM02 plugged into the headphone jack and nothing playing, I hear a hisss sound. Like empty radio channel when u searching for stations, if u get what i mean. I have to turn the volume of the song higher than usual to drown out the sound. I dont get that the sound when its plugged into my iphone 5.
With my headphones (Soundmagic HP-150), I dont hear that background sound.
How do i get rid of the sound?
Add-on: when starting up laptop, also got sounds. is it cause of the impedance thingy?
StereoLoft
Featured Sponsor for Headphones and Earphones
Hi Feralslash
The hiss sound you described is likely caused by the laptop due to a number of reasons
1) The hiss noise might be heard only when the charger is plugged in, remove the charger if it's not needed, Balance Armature drivers like those used in the IM02 is particularly sensitive enough to pick up the noise caused by the charger
2) Space constraint in the design of a laptop forced most manufacturer to place the sensitive audio related components (like the built in sound card) closed to other components that generate noise (EMI), even worse those sensitive audio components share the same power supply with other components that will pollute the power supply, causing more noise:eek:
If unplugging the charger don't work, one effective way to solve the problem is by using an external DAC (Digital to Analog Converter), when connected those DAC effectively takes over the task of the computer's sound card, and since they can be placed further away from device that generate EMI they are more immune to such noise, in most cases an external DAC + headphone amplifier will out perform the computer's built in sound card due to better circuit design and components used
Feel free to ask us more question if you have any doubts :D
Hope this helps:)
It's probably the laptop. I have the Aftershock X15S V2 (Clevo P150SM-A) and I have hissing on my headphone jack too D: Have to check with my brother if his Aftershock XG15 V3 (Clevo W355SSQ) has the same problem too.
Usually more sensitive IEMs should be able to pick up the subtle noise in the soundcard.
feralslash
ok. time to find a dac/amp that can work for both laptop and iphone, without breaking the bank
xuan87
Fortunately, there are many such options available and many places to audition them. Enjoy the next part of your audio journey!
xuan87
Audio Technica releases new models in their professional line up!
M50x-DG (Limited Edition model of M50x)
ATH-M50xDG | ????? | ?????? | ?????????
M70x (New flagship monitor)
ATH-M70x | ????? | ?????? | ?????????
R70x (New open back flagship monitor)
ATH-R70x | ????? | ?????? | ?????????
M70x MSRP is US$419.
R70x MSRP is US$489.
But based on the other prices floating around, I think it would be in the $400-$500 range.
Thanks for the heads up, all interesting. I though the limited edition M50x will be red like their other limited edition gear, but they chose deep green and brown (looks black and brown on my monitor).
I thought the R70x will just be an open back version of the M70x but apparently, it's a different beast altogether. The R70x can be easily made balanced too just by changing the cable.
Will be looking to testing both of them once they're in Singapore as I like the sound of the MSR7 and CKR 9 and 10.
essentiale
Does anyone have experience with the W1000z and can share your review please? I'm considering a future closed back can upgrade from m50x and thinking about w1000z, a2000x, Sony Mdr-z7... Thanks!
