Ask a Bicycle Question - Part 5
smoothtalker
Suspended
I've cycled with LCSG a few times...it's geared mainly for beginners and those who want a slightly slower pace. The ones who should avoid this are those who want to do road work and MTB trails.
no issues at all with the above, most importantly got xmm there? 16 to 21 xmm have?
Sadisticnoob
Huh?
Why spend so little on bike lights? Need good lights that are bright so that other road users/drivers can see clearly.
the $2 lights are super bright, good value for money better than my S$20 fizik ics lights
smoothtalker
Suspended
Huh?
singapore drivers a lot don't care you one. LOL... seriously i got one cygolite flashing 600lu looks like ambulance they also don't care.
MIVEC525
Use this....mine works!
iamlenon
i release foldie rim or tyre they use numbers like 451 406 etc..
what are those? :s11:
SmilingDevil
406 is for your normal 20" tyres. 20 x 1.0 to 2.125 sized tyres.
451 is for more slick tyres using 20 x 1 to 1 1/4 sized tyres.
Noted one type uses decimal numbering and the other uses fraction. Both are considered 20" but the fraction one is slightly wider in diameter.
Jwee85
1)what is the normal rate for a bicycle tyre to deflate? one or two weeks?
2)Is it true if I cap the tyre valve tightly(with a metal cap) the air in tyre will not leak as quickly with a plastic cap?
3) How best to lock my $5,000 bicycle outside the corridoor, to avoid theft?
