check with you guys, i have installed shafa market yday and was testing out the inbuilt network speed check, the speed was real bad and even downloading updates like chrome also took like 30 mins
my box isnt "rooted" yet so cant use google playstore yet but not sure if it is the cause, i have also restarted my router and tested my internet speed, everything is as per normal..
any advise if theres something i'm missing out?
lastly, by resetting to factory defaults, it should clear up and return to the out of box condition right? (i got it from the lazada seller, so nothing special pre-installed)
thanks all!
