Fiio X1 Thread
GotBeOwned
Ehhh anyone experencing the X1 sometimes will auto pause for no reason?
And I can't seems to change the sleep function.. It always stuck at 10mins. I press anything also no response...
just bring the unit back to the seller and ask them to take a look at it and compare with their demo
john doe 84
Hi guys,
Sorry if this has been asked before...but does the FiiO X1 take AIFF files?
AIFF, not WAV as I like to have my metadata with me.
On a sidenote, anyone knows if there are iPod Classic repair services in Singapore?? I have the 7th Gen 160GB iPod Classic - it's starting to get crazy...keeps hanging, skipping tracks and being very laggy
GotBeOwned
Hi guys,
x1 plays .aiff
HyperBaka
Now any promotion for the fio x1?
Planning to get one at the current lowest price :D
leonaheidern
Got the Gold Fiio X1 with the (Fiio E11K that I got from Japan)
and stacking kit from E1 yesterday.
Fiio X1 came with firmware version 1.2
Using a Sandisk 64GB Class 10 Micro SDXC 48MBPS 320 X UHS-1 Card that I picked up from the Challenger Members Roadshow at Ion Orchard Basement 2 outside of Stereo Electronics there for 53 SGD with the X1.
Had the player hang while updating media library at song no 2620.
Followed the faq here.
Basically i followed post 6 with Tag Scan and rename all the files to similar case.
After i renamed I popped the sd card back into the X1 and it managed to get past song no 2620 successfully.
Hope the FAQ helps anyone who has this problems as well.
http://fiio.me/forum.php?mod=redirect&goto=findpost&ptid=39965&pid=105671
Q: What to do if “Update Media library” on the X5 causes hangups?
A: If the X5 hangs while updating the media library, it will still hang on any subsequent attempt if no changes are made. The first thing to try is to eject the micro SD card(s), update the media library with no cards loaded to clear the database, insert the card(s) again and try updating again. If the update still hangs, then it is caused by certain problems on the card(s) or certain problems with files on the cards. Please try the following:
1. Run SAMediaScanner (Here is the link for download: SAMediaScanner.exe_??????|??? ??-?????) on your SD cards to scan for files with errors. If any files with errors are detected, please delete the files (re-encoding the music and re-testing if necessary) and run the media library update again; if the update still hangs,
2. Please examine the SD card(s) on the computer and delete files with .log extension or any other non-music files from the card(s) and run the media library update again; if the update still hangs,
3. Please try the following method:
(1) remove the cards and do a library update (clears the database)
(2) move half of the songs out of the card (e.g. half of the folders), insert the card and try the library update again.
(3) if the update succeeds:
a. add half of the folders you moved out back into the card (for a total of 3/4 of the original total) and try again
if the update in (2) fails:
b. move out half of the remaining folders (for a total of 1/4 of the original total) and try again
if the update in (b) succeeds:
i. add half of the folders you moved out in (b) back into the card and try again
Basically the idea is to use a binary tree elimination to find song(s) or file(s) that are causing issues with the library scan.
Post #6
I recently bought my X5 with 2 x 128GB sandisk sd cards. I flashed to firmware 2.36 beta. I formatted the card inside the X5. Next I connected the cards to my pc and copied my music collection on to them. I have almost 32000 files mostly in AAC format (m4a) which I ripped from CD using winamp over the last 10 years. So I was not happy when I tried to update the media library in X5 and it freeze.
So I did research. Maybe this is faulty sd card. I tried different cards - same problem. Then I found this thread. I followed the suggestion the first post. Using this binary tree elimination I could finally find at least one folder containing files that caused hanging. But I have a large collection, so it would take me months to go through all files and eliminate the bad ones.
I tried SAMediaScanner but it only support mp3.
I suspect that the problem is with the meta data tags, but nothing is obvious from the "bad" files I found, and I want some way to identify all the bad files quickly.
Then almost by accident I discovered TagScan TagScanner - the ultimate Tag Editor
With this program I did not figure out how to find the bad tags, but I was able to retag my whole collection very quickly without losing any meta data.
And that was all I needed. After that I copied all my collection to the cards again. This time when I update the media library, after 45 minutes 31800 files detected!!!
So I thought I would post here for anybody else having issues. It might give you hope
XHolyz
Hi bros, want to ask where can i get a cheaper price for Fiio x1? Planning to get 1. Gum xia
zxtay1
Fiio booth
Bro, this few days, One km mall has Fiio booth, i saw their posts on fb say got promo, maybe u can go thr take a look.
fumoffuXx
Keep in mind saving afew bucks on tougher methods to claim waranty....not worth it
lunarsong
lazada.sg sells x1 for $149, 17% discount. not sure how to go about the warranty but you can give them a call.
if u wan to buy from local shops, can try buying shopping mall vouchers which can be used in these shops (ConnectIT, Tampines 1/JEM, Asiamall vouchers)(Stereo, Ion/PS, Capitaland vouchers) at a lower price.
Still can get a lower price but abit laychey.
if not just wait and pray for CNY promotion :s12:
zxtay1
yeah lor, maybe can wait for cny promo. anyway i think the price at connectit quite reasonable if u are member. i just got one today.
xxvii27
I just ordered a x1 (used to owe a sansaclip but decided to get a x1 to try) and i have a E11.
Is there any difference between the E11 and E11k ?
And how does the E11 stack up with the X1 compared to the E11k?
bjory
Anyone knows how I can let X1 show as a removable drive in Win7?
When I plugged into my PC it doesn't show as a removable drive. It just showed on the X1 itself that it is charging.
So if I need to add songs into the SD card, I need to take out the SD card and use a card reader to do that.
Narukura
I turn it on and plug it to the com. It always appears as removable drive for me.
rickysio
IIRC check your settings on the X1.
