iPhone 6 PSAJ Case
Ian
Where can buy it beside Apple Store?
Which shop have it ?
*adiBOY
Apple Store selling for $39
How much they selling?
They are selling for $39 too. Do note that PSAJ in Apple store are different with the ones selling at retails. Check out the images at Apple online store and PSAJ website.
Sebbyng
2 versions of PSAJ
There are 2 versions:
1 without Screen Protector
1 with SP.
So if you need a SP then get with SP. Price difference is about $10.
hawkz02
1 with SP.
FYI there 3 version
Jap version with sp
International version without sp
And apple store version
Ian
FYI there 3 version
Jap version with sp
Yes after much reading, you're right.
Dunno retail or Apple Store version got extra "Lip"
hawkz02
Apple store one got extra lip. It fully covered meaning the bottom right is covered which the retail one off the shelf does not.Retail one bottom right portion is lower.
Jap version and international one other than the sp included the quality also different Which Jap one is better.
kingsen
Hi bro, whats the distinctive difference between these 3 version other than the extra sp ?
hawkz02
The only different that noticeable is between apple store one and the other two. Apple one got extra lip meaning it is higher and also the gap at the bottom right is covered up.
The other two is same just some qc issue where Jap version is better. I had one clear international version which got bubbles inside.
ragnarok95
Senior Moderator
Senior Moderator
I have BOTH the apple PSAJ Force and the normal PSAJ.
My take after using them is, GO FOR THE APPLE PSAJ FORCE. It's much better in almost every ways.
fuzzybear
agreed i love the Apple PSAJ
but i now also using UAG maverick
due to more protections
Ian
I love this product but beware..........
It starts to peel off after 2 month usage.
So please don't buy and support other better one available out there.
metamofia89
I got the PSAJ from Apple a week ago and i shared the sentiment with the one and only reviewer from that store. Basically it has a more prominent lip than the one i bought from P2O mobile and the bottom right is also fully protected.
Problem is, the fit is extremely poor. When i put in the phone, the phone jiggles and move about. Besides that everything seems fine. Had to remove it cause i cant take the loose fitting of the PSAJ.
Im not sure if i got the bad sets because the PSAJ i bought from P2O fits my phone to a T. So you might consider where you're going to get it from.
Ian
Mine is from NuBox.
Paid for $49.
Very happy with its tight fit and slim design.
Only last for 2 Month so with that amount I paid for doesn't warrant a good review from me.
ragnarok95
Senior Moderator
Senior Moderator
PSAJ coating will peel off. This is discussed since iphone 5 time and i mentioned before. White matte, black matte, clear, smoke all will peel off to reveal the base clear casing. It's after all, just a coating.
I am not so concern about the peeling. I buy the PSAJ to protect my phone, not to look nice on it. :)
