iPhone 6/6+ Screen Protectors
weewee81
Abit blurr...
kingsen
Any one got use the back screen protector ? If paste tat back screen protector still can fit in psaj ? Got 1 spare back protector lying around.
b0ib0ii
hey guys, is this only happened to me or all the 6plus black screen as well?? basically i have been trying a lot of fully covered edge to edge tempered glass SP and whenever after i applied the SP, the screen will have this additional 'border white line' appeared on both side of my screen and no matter how i clean it will still appeared there.
jaymessofly
It's an air bubble. As the screen protector doesn't curve along with the screen, an air bubble forms.
Slowx6
Bough mocolo full tg. Tried to apply. However at all side that's near the white broder, it appear to have a whole stretch of air bubble. How do i remove it? Kindly advise. Thanks
sigurros
Am using mocolo as well. Try using a microfiber cloth and apply some pressure to 'push' them out. I am using the black one. Also the same. But managed to do so.
jaymessofly
Using naked with Mocolo full screen TG on my 6. Have a white border as well. Are you using a 6 or 6+? I was led to believe that this problem wouldn't occur on the 6+.
EJB
I left it be, didn't matter to me, I reseat too many times already.
siron
Bought mocolo as well... Yep same issue. The side cannot be stick. Sadly. Well the seller only can offer me half price to buy another set.
kingsen
bought mocolo for my 6 plus as well. Also one stretch of air bubble at side. Need alternatives...
jaymessofly
My second Mocolo chipped again within a week. No drops whatsoever. No idea how it happened at all.
Giving up on full coverage SP I guess. Either that or going for branded ones, hope they'll be of a better quality and last longer.
radzkal
mocolo full coverage with thin borders? u need to keep "massaging" the side with microbubbles. i had minor small stretch of microbubbles and i spent quite some time after applying to try push the bubbles out. now, weeks on, cant even see the bubbles at all. luck, i guess.
