Air conditioning - Any recommendations please??
terumo
To LOLLIPOPPY,
If extended warranty, gas is low, they shouldn't top up the gas.
They should find the source of the leak & settle for u.
You shouldn't be charged for gas top up in the 1st place.
lightchaser
aircon
hi,
Anyone can recommend a cheap and good aircon for 2 bedrooms ? dun need to last long , only about 5 years as will be enbloc soon.
Or maybe a second hand unit better ? thks :)
kimsim
Suspended
hi,
Www.gumthree.com.sg
Has a lot used Aircon, can consider for Starmex inverter so far so good they will do refurbish the unit like new
kimsim
Suspended
heard pana the blower is more powerful then mhi and starmex?
But Pana blower can't even used quiet mode.
You would realise that is very warm and not cold at all.
But ME or MHI can use with quiet fan n set with 25C or 26C
kimsim
Suspended
Hi is there any different between ME MSY-GE10VA & MSY-EF10VA? Other than the looks.
GE10VA quite common already the design from 2010 till now, for the EF10VA they called it Zen for flat panel and comes with 3 colors, Black, Silver, White.. mine is white for living room EF12VA model.
But EF model is non easy clean feature already, if you know how to screw out the casing should be no problem like common brands.
also EF come with bigger Remote control for allow you set in daily scheduler and the rest just like normal GE.
Remote here.
The outlook design.
xiaohanhan
Remote here.
The outlook design.
Thanks! What about the filtering? GE got anti-allergy enzyme and catechin plus air purifying system. What about EF? Are those important?
Because I'm allow to change 1unit of GE to EF. So i dunno what the difference...
kimsim
Suspended
Not too sure that anti-allergy thing, since day 1 i already pasted with extra filter and the rest never bother it :s13:
If you more concern about easy clean and 19dB for quiet mode, i still prefer go with GE10VA model, even my bedroom also using GE model now.
The feature can refer here : https://www.mitsubishi-electric.co.nz/heatpump/product.aspx?item=69083BW
xiaohanhan
Thanks! Think i gonna go down and ask more about the features. design to me are least important. I'm more interested in the features.
ipaq4444
I'm looking to buy a System 4 fr Gain City to cool 4 HDB bedrooms (1 room is converted fr study). Considering System 4 from MIT HI n MIT ELE. Both abt same price. Any recommendations or advice?
MIT HI:
SCM80ZJ-S1(31000 Btu) + 3X SRK25ZMA-S(3x9000 Btu) + 1X SRK35ZMA-S(13000 Btu) for $3829.
$150 for steel bracket
$240 for upgraded piping n insulation.
FREE 5 years warranty capped at $1850 claims amount.
ADD $129 to make 5 year Warranty at UNLIMITED claim amount.
Add $580 for 2 year servicing (twice in 1st year, 3 times in 2nd year)
Total $4828.
MIT HI is a newer model with more features like louvres tt go up down n left right, self cleaning function tt dries up moisture (hopefully odour) internally,generates negative ions tt supposedly keeps air fresher n cleaner.
MIT ELE:
MXY-4A28VA7(28000 Btu) + 3x10000 Btu + 1x13000 Btu for $3839.
Total $4838.
MIT ELE is 6-7 yr old model whose louvres only go left n right. Its only obvious plus point is tt it's probably quieter.
Are these fair deals? Any discounts or freebies tt I can get fr GC at EXPO fair this SUN?
Tks for replies n comments.
If you were find out in proper from Mit Starmex was higher BTU output.
7.5kw cooling capacity x 3418 = 25,635 BTU for starmex
SCM80ZJ-S1 Air Conditioning Splits Multi outdoor units - RAC
if look at this mhi compressor does have a higher btu output if do the comparison between starmex.
ipaq4444
Gurus,
in this case, can i say the correct comparsion for compressor should be SCM100ZJ-S1 vs MXY-4A38VA?
is there any advantages in getting a bigger compressor? if the 3x room blower is based on 9k btu and the hall on 13k btu? if the max intention is to only on 1 hall and 1 room ( 13 + 9k btu) = 22btu?
Then if want to on 2 room and the hall then should got a at least a ( 13+9+9K) = 31 btu compressor?
kimsim
Suspended
Gurus,
Let's comes we talks about BTUs.
When starter compressor kick in.. For each room at least needs for enough higher cooling capacity for faster cold down & enegy saving for reduce in part loan.
But system 3 or 4, has to divide each room and sharing BTUs for depends each see wether which room more faster cooling down.
In theory if under power BTU for sure It is does not cold enough.
But after I realise my MXY-3A28VA can achieved the cooling for each room.
In the computer would tell the PCB splits out each room in the low BTU when starting runing will be slower only.
Once temp reached from the pre-set.. Even 50k BTU also useless.. Cause when starter needs more btu to supply each within fews mins to getting cold.. The deffence only less than 15mins slower for each room to getting cold down timing.
To compare my single split.
terumo
To ipaq4444,
For ur requirements, 3a28 should be enough as a bedroom requires only 6-7k btu.
