ONEPlus ONE phone
garychengjw
First look at OnePlus’s OxygenOS reveals a flat and colorful UI
OnePlus OxygenOS
highdiver_2000
My advice is don't buy.
I bought some during cm10 days... in the end not compatible or looks like crap on cm11.
Then my cm11 ones now not compatible with cm12...
Although they are saying something about refining the theme system so that themers can support both cm11 and cm12 at the same time but I'm not counting on that.
So if you buy cm12 themes now and next android version M and cm13 chut more pattern with themes, you may end up wasting money instead.
CM10 and very late CM11 are using different theme engines.
ciwrI comments on Steve Kondik giving his side to the OPO-CM row
Personally I am not really particular about the icons. Except for the one time when I reset 44S and got a theme update. That really f*** everything big time for me. Icons became smaller and difficult to differentiate.
I have to download an icon set. And got more problems, Echofon had a blue background. Blue on Blue. Much later when I upgrade and downgrade Android, this time smarter, rejected the theme update!
TL;DR Try the themes, double check ALL icons to see if they are readable. The designer can't cover all apps.
Gex
Tempered Glass Screen Protector Review
Bought a "Cmei Tempered Glass Screen Protector" from vendor Taozi on qoo10.sg
Item arrived within 3 working days. Glass is "2.5D" edged, feels oleo-phobic and application is great. I misaligned first time, and was able to lift off and reapply with no problem. Package is rather minimal, with alcohol wipe, and a cheapo dust "cloth".
It doesn't completely cover with the glass on the OPO, with a space of 0.5mm to 1mm, but since I'm using a Diztronic case, it helps with the fitting. Great value for SGD5.5. :D
mamboeidos
Because N6 too sexpensive and not really that interesting to me.
And CM supported officially (for now) on a phone is icing on the top.
Bur now no more liao rite? That y I thinkinf should still buy anot. Not really into flashing
shawniiex
Woo hoo, more reaffirmation that my case works with glass.
