garychengjw
- Jul 18, 2010
teaser of the new oxygen os...
My advice is don't buy.
I bought some during cm10 days... in the end not compatible or looks like crap on cm11.
Then my cm11 ones now not compatible with cm12...
Although they are saying something about refining the theme system so that themers can support both cm11 and cm12 at the same time but I'm not counting on that.
So if you buy cm12 themes now and next android version M and cm13 chut more pattern with themes, you may end up wasting money instead.
That sounds stupid. They already have a lollipop alpha build, why fake one video using Kikkat?Somebody did a freeze frame step through. The build is actually a kit kat with a nov build date.
Now still worth to get opo or nexus 5?
I moved from N5 to OPO.....u decide.Now still worth to get opo or nexus 5?
I moved from N5 to OPO.....u decide.![]()
Because N6 too sexpensive and not really that interesting to me.Wats the reason for the move?
Buy the china sets from Qoo or Lazada lagi cheaper.....no need get from OPO site.So I can just buy grom the site n straight away use rite? Not lick or restricted in anyways?
And CM supported officially (for now) on a phone is icing on the top.
Bought a "Cmei Tempered Glass Screen Protector" from vendor Taozi on qoo10.sg
Item arrived within 3 working days. Glass is "2.5D" edged, feels oleo-phobic and application is great. I misaligned first time, and was able to lift off and reapply with no problem. Package is rather minimal, with alcohol wipe, and a cheapo dust "cloth".
It doesn't completely cover with the glass on the OPO, with a space of 0.5mm to 1mm, but since I'm using a Diztronic case, it helps with the fitting. Great value for SGD5.5.
