xbmc live tv
tony_ong
can we use it on a pc and get live sports stream?
new to this xbmc thing.
thanks
gregory_choo
Greg, the XBMC/Kodi link in the pinned post down?
A fren was asking n I tried, it was down... Maybe u wanna edit it for easy reference?
Thanks for informing me.
Just fixed up the link. Should be working now.
Jeffsrightnow
KODI 15 ISENGARD COMING YOUR WAY MORE IMPROVEMENT
MANY FIXES & IMPROVEMENT FOR KODI 15 ISENGARD.EXPERIENCE THE ALPHA VERSION.
Chapter Selector Window.
Audio and Subtitle Lists.
Language Add-ons and an Expansion of International Options.
Add-on Manager Improvements.
Other Improvements.
There were 241 fixes, features, and improvements for Alpha2. Beyond the highlighted ones, here is a list of a few other improvements made.
* Tuxbox removal. Users of Enigma2 boxes can use the VUPlus PVR add-on
* Split PVR add-ons into separate projects
* Fix season art scraping on newly added seasons
* Immediately fetch updates from repository after major upgrade
* Improvement of installing new skins selection
* Remove legacy code pre-Frodo 11.0
* Add jump to first unwatched in TV section
* Remove certain codecs from our core code and made add-ons out of them. Audio encoders/decoders
* Removal of AFP filesystem support
* Windows DXVA HEVC hardware decoding support if driver and hardware support exist
IF YOU HAVE SPARE BOX YOU CAN TEST IT.BELOW ARE 2 VERSION FOR DOWNLOAD.THE ALPHA VERSION & MODDED VERSION.
OFFICIAL ALPHA STAGEhttp://mirrors.kodi.tv/snapshots/android/arm/kodi-15.0-Isengard_alpha2-armeabi-v7a.apk
MODDED VERSIONhttp://www.mediafire.com/download/c19gacidlij3z29/kodi-15.0-Isengard-Wizard1-Alpha1.apk
Jeffsrightnow
No More Side-Loading: Official Version of KODI XBMC Available in The Google Play Store.
1e6f36_500f44429c5249d08d43d5ca0615b6f5.png_srb_p_629_557_75_22_0.50_1.20_0.00_png_srb
COMING SOON!!
Official XBMC KODI Android Application is making its debut in the Google Play a Store. It's not available to the masses just yet but you can join the testing community and request to install it now! Be one of the first to install the very first official version of XBMC KODI from within the Google Play Store!
You need at minimum Android 4.2 on your device.
HOW TO INSTALL KODI 15 Beta from the Google Play Store to any Android device:
1. Join Kodi Beta Builds group
2. This community is purely setup for Beta testing new releases.
We will not provide support in this community in any way. For feedback you must visit our official Kodi forum.
After you have joined click the agreement for receiving Beta builds:
https://play.google.com/apps/testing/org.xbmc.kodi
If you are member of both Alpha and Beta group you will receive the highest version.
Important is that you use the same ACCOUNT as you use for Google Play store and accept the agreement.
You can cancel receiving the Beta builds by visiting the same url.
buzzmcfly
New to KODI
Just installed kodi on my razer forge tv... do i need to get a smartdns or a vpn?
if i dont will i get into trouble?
Jeffsrightnow
Great....how the razer forge tv performance?You dont need vpn for streaming unless you choose specific addon that require vpn to excess.
buzzmcfly
its okay... i think. the forges cannot support netflix at the moment and the usb port is only for input devices and cannot be used for external storage. i installed Genesis, do i need a vpn?
Jeffsrightnow
Well.... heard about that nexflix not supported on Razor forge tv but im not sure if it can bypass netflix thru Kodi have not tested so far.No vpn required for Genesis.
I'mknotdumb!
Other Improvements.
Any special function on the modded version? or about the same as the official version ?
Jeffsrightnow
This modded version there some file changes on the performance.Some user test it & revert it blazzing fast.Nowadays there is too many custom build kodi available such as shannon,gandelf build & many more you can try.In US is a competition:D
