[SSD] Secure Locked Plextor M5Pro Xtreme
tony_ong
Hi,
I like to check how to unlock the SSD to do a low level format?
I tried to run secure format using the plextool but it says that the SSD is locked.
Thanks in advance.
acehigh
Hi,
Thanks in advance.
If it's frozen u need parted magic and a thumb drive. Google it.
Wongpk
hang say hang lah
ssd must put inside freezer then call frozen
:s22::s22:
BenLeeSG
try un-plug sata & power cable from the ssd then plug in again.
its should solve the frozen issues
koreanlover
You can also try to put your computer to sleep mode, then switch on the computer. Then run Plextool.
MoneyFace =p
Hang? It didn't hang. I can still boot into windows and use just that i cannot do secure format
Disregard him. He don't know what he is saying. :s22:
Try turning on SATA hotplug for that particular port, secure remove the SSD while you are in Windows and replug in back (both power and data cable).
tony_ong
not sure how to secure remove.. but i tried the safely remove thing and disconnect and reconnect but it doesnt solve the problem..
i guess will have to download parted magic and try to use it to do a secure erase.
tony_ong
secure lock, you mean secure lock from bios ?
the Plextool says "Security frozen lock might be detect on the drive, so please replug your drive to start Secure Format."
I tried replug still same. :s22::s11:
ondooy
bios can secure lock a hdd or ssd, so you'll need to unlock it from bios if it was locked from there...
if it was locked from another computer, you'll need that computer to unlock it..
tony_ong
oo. i took it out of my laptop that i seldom use now.. but in the bios of the laptop, there is like no option to lock/unlock?
ondooy
have you tried diskpart ? delete the ssd partition ?
tony_ong
nope. haven try.. now i thinking if need to do secure erase or not.
jus now i went to computer management and delete the partitions on the ssd and recreate it. now AS SSD give a 308MB/s write and 490MB/s read...
thought the more proper was is to do a secure erase instead right?
tony_ong
if you selling it, then yes...
i think for now i will be using it as storage on top of my current system ba.
i think the AS SSD result i get is almost the peak performance of this plextor m5pro xtreme 128GB can get?
