camelsback
- Mar 20, 2013
any workshop to recommend to do conceal wiring? <$20
i have the equipments/wires
thanks!
thanks!
interesting... i had a 64GB Sandisk Ultra 30MB/s that only lasted 4 months, suffered similar symptoms until the point where the files cannot be deleted from the SD card, nor formatted. current 64GB is 3 months and counting. and this is with fully sheltered parking day and night (ITB-100SPW).
mine also encounter the same issue as SD cards kaput....already changed
three cards and all are original brought from Sandisk distributor..
I'm using the ITB100 Wifi model .... I have similar issue. Bought a 64GB SD card and only lasted about 2 months ... failure mode is exactly what you have described ... put back the original 8GB SD card that came with the camera and so far so good ...
My car also parked under open car park in my office compound ...
Current my ITB100SPW is on firmware v1.0. There is an update of firmware v1.1 from their official ipassmall website. Anyone has flashed it to the latest update and does it have the english language option?
Hello guys, where can we get installation done if purchase from other user selling their set or buying online?
hmm... seems like i'm not alone! though different models, i assume all are sandisk cards? anyone using other brands and also having the same problem?
hey all,
have been hearing beep beep sound (non stop) when i parked my car overnight.
have to pull out the cable and insert again to reboot it. Is it my battery good game liao?
btw the way, i just realised it have previously stopped recording for about 3 months (my fault for not checking, and lucky no accident)...
Hello guys, need some help on itronics ITB100SPW.
got it today, check the SD card, found the Setup.bin but no PC installer.
downloaded the Blackbox PC player v1.4, streaming videos are working
As voice is in korean and is recording every single minute, i need to change the settings. I formatted my SD card and selected my settings and click ok... but when i go back to check it is reverted to original settings. Nothing was saved!
went back to the car to check... still korean.
zzz
can anybody advise why my settings cant be saved?
