XiaoMi MiPad
yiptw89
Anyone got Motorola Turbo Charger (included in Google Nexus 6, Motorola Droid Turbo) or Samsung Galaxy Note 4 fast charger to test the 9V charging speed on Mi Pad?
Mi Pad supports chargers rated at 5V@2A and 9V@1.2A.
Source: http://www.mi.com/mipad/#function
porcu
Source: 小米平板电脑——小米官网
Think only Qualcomm chipsets are supported.
My Nexus9 running same chip doesn't charge faster.
Sheldon99
anyone knows if the OTG + USB modem dongle will work?
think may need to root... haiz...
BTW, found hidden menus:
CIT:
Settings > About pad > keep tapping on Kernel version
Developer:
keep tapping on MIUI version
Bug report:
keep tapping CPU
PAD info:
Internal memory
Kitkat:
i didnt know tapping on Android version works for other androids as well (works on my mobile)
kazuki666
Those whom had order on the yesterday (12 Feb), have you received today le? I was still praying for speedy miracle for today, but didnt happen...:s13:
arcturuz
there's this setting called Wi-Fi optimization under Wi-Fi Settings
It says Minimize battery usage when Wi-Fi is on
wat exactly does this do ah
yhw22
For those having problem like unable to install Youku can go below website to install it.
app.mi.com
arcturuz
You mean someone reported having problem charging either the given 2 or 3 pin charger?
no la the charger for redmi phone
think it is lower voltage or wat, but since it is already plugged to my wall, i tried to charge my mipad with it
prbly will take a longer time to charge than the supplied mipad charger
