ONEPlus ONE phone
kennyboy
Battery life seems to be the same for me, 1% per hour at sleep. On 05Q
kennyboy
Observed Negatives:
Battery seems to suck.
Lag detected at Boot Animation.
Observed Positives:
None.
Maxxaudio I don't use.
Swiftkey no Chinese option. This was the main reason I wanted to try 05Q.
Summary: Don't bother to go 05Q.
Don't seem to observe your problems. Chinese in Swiftkey is something you have to add inside Swiftkey itself, always has been that way.
Hey, you could always roll back to 44S. :D
Slpy
Hi bros out there. I need help. I bought the OPO set sealed from a fellow Carousell-er like around 5 months ago. now the screen have some touchscreen issues where it registers touches even without me touching it. Did a clean wipe and reinstalled CM11s and even then the touchscreen still going crazy. I can still use and touch the screen but sometimes the phone just go crazy.
The thing is, when i login to the OPO site to request for RMA, they need order number. any workaround for this issue? or you guys know anywhere that does a repair like.. professionally? I went to bugis and they quoted $180 for LCD replacement even without checking it. lol. read from a fellow forumer at OPO forum and he said its some grounding issue where the LCD flex cable is in contact with the metallic chassis.
what's your opinion? TYIA! :D :D :spin:
which bugis shop you went?
Tooi Kono Machi De
My One Plue One Phone finally arrived...With Google playstore in it somemore @@ Thot needa flash @@
Anyone got Shawn (Diztronic) contact? Nid contact him urgently for cover :D
mamboeidos
mine also arrived liao just flashed it ...but how to like install titanium backup or those backup tools for free ah?
have to root it ? or its rooted already when i flashed it?
