XiaoMi MiPad
mingfreakrsx
galliano
Just flashed my local set MiPad to the China ROM. Is there anyway to reflash it to the Global ROM?
Was using the MiFlash method via PC.
I tried to revert back to the Global ROM but it was unsuccessful.
wind23
Screen unresponsive after waking from sleep.
Hi, just checking if anyone having problem of screen being unresponsive after waking from sleep and needs to on off it again?
Just Me
Thanks. I forgot to reset my "Fastboot script in Advanced settings". Thus always could not flash the rom. Thanks a plenty
Can you point a link to a fastboot app which I can flash the v40 rom for my redmi note 3g? Thanks..
kazuki666
Have a few questions for the Mipad
1) Is the Mi app store supposed to be default installed on this tablet de? I cannot seem to find it...
2) Is it possible to display the battery % life on the top right corner?
3) How do I install any widget to display more information on the lock screen? I wish to display battery life as well.
arcturuz
U guys using mipad on balanced or performance mode?
Tried balanced but performance seems to give a smoother experience even when surfing hwz forums.
Yuripa
2) I'm not a mi pad user but assuming that it's the same as redmi 1s, then yes it's possible to display battery percentage on the top right hand corner of the screen.
3) Download this app - wp clock 2
Its not really a widget, more like a home screen or lock screen. You can customize the information you want including battery percentage, weather, telco company, wifi strength etc. I'm using this instead of displaying the batt per by default.
