Xiaomi redmi note
tjkb230
lousy v40 update...
seems like xiaomi is moving backwards rather moving forward
now the phone can't read Korean characters in the default mp3 app with the exception of web browsing :s22::s22::(:(
haven't try Japanese characters though :eek:
Skyeagle
Sighz... When is the miui 6 coming?
Correct me if l am wrong:
Miui 6 global rom has already started rolling out for the redmi note 4G version?
Just Me
Sorry it has been a long time since I updated my note's firmware (3g, global) so currently it's rooted. If I wanna do a full wipe of data and cache before flashing to the latest v40, I just go to recovery mode, select wipe and reset then flash it right?
Soccerpunter888
can anyone help answer me really really newb question for those who already bought it from the mi website, it comes with google play,right? I heard what the china version don't have google play or some sai
i just bought it for $229 from the website (xiaomi note 4G) :o:o
mingfreakrsx
If you got your Redmi Note 4G from mi.com/sg , then it will be preloaded with Google Play services.
If you got it from China, then you have to separately install Google Play services to it. :)
Sent from my Mi device using GAGT
KleoZy
for those who uses the China default rom that does not have google play. I would advise you to search for google installer apk.
as google play will need additional google services. hmm wonder it's long time I have not posted here so am not sure am I allow to show links here.. anyway for those who need the installer, it should be here Find all the Google Apps in Google installer! - App - Xiaomi MIUI Official Forum
Cissiboy
twentytwoeighty
never gonna buy xiaomi phone again, the os update is non-existent like samsung's ...
AHAHAAHHAHAHAHA...This is the biggest joke I see today.
When I paid ~4x more for a Note 3 at the very least it should it should perform just as well as the Redmi Note in everything, not having some f'ed up unstoppable indexing service or Samsung bloatware/Touchwiz to drain battery life like no tomorrow and make the Xiaomi look godlike in comparison.
slashGNR
why??????????
My Note 3G camera is giving problems, not sure it happened before or after updates. A few times after taking a few shots then realized it's not working at all, got to reboot to make it work...
Still the same, first Note and last...
Just Me
I noticed that even though I did a full wipe and factory reset in recovery for my note 3g, the installed apps still remain.. is it a bug?
LameEntertainer
anyone have the bug issue with the international roaming?
mine keep asking me to add exceptions into the international roaming so that I can use the internet. any idea how to off it? damn irritating...
using version 40.0 btw...
mad0n3
What's a good rom to root for xiaomi note 3G?
And how to backup data onto the computer? (e.g. Apple has itunes, Samsung has Samsung Kries.)
Thanks! :)
hyper_megaman
dig within this thread, this has been discussed to death
there's a very easy flash to root kit that doesn't change your rom, just changes a registry value iirc
jedi5diah
What's a good and stable custom ROM to flash into the redmi note 3G?
go to miuidroid.com, they have weekly dev release, and are customised to international version.
don't even need to root or what just flash with select package at updater.
latest recovery allows you to revert to previous rom, rem do not flash twice if smth screws up, go back to the functional rom and flash again. if not it will keep the wrong rom as backup.
