XiaoMi MiPad
dennizm51
2) I'm not a mi pad user but assuming that it's the same as redmi 1s, then yes it's possible to display battery percentage on the top right hand corner of the screen.
3) Download this app - wp clock 2
Its not really a widget, more like a home screen or lock screen. You can customize the information you want including battery percentage, weather, telco company, wifi strength etc. I'm using this instead of displaying the batt per by default.
Thanks for the app! it's very useful.
Amigogo
anyone using nova launchers with mipad? how come when i tried to go in mipad settings in the nova launcher, it will shows error
then when i go back to miui launcher, its ok....weird..
kazuki666
Any good media player? Use vlan but some mkv unable to play
Sent from Palm Treo using GAGT
mx player is probably the best available in Play liaoz. The only issue it sometimes get is when the developer tries to upgrade it for new firmwares, then some users may be stuck, but usually this will be rectify pretty fast.
Hi dude. Thanks for the recommendation. I tried it on mipad le. It does work for the wallpaper on homescreen, but I cannot seem to get it working on the lock screen... :(
Anyone has other solutions for the battery life display???
kurt111494
Okay, I think after reading the posts for these few weeks, I'm a little skeptical about MiPad performance/reliability lol.
Guess I'll just fork out a little more and get Samsung/Sony tabs instead :/
yiptw89
Remove the Settings shortcut on your home screen. Tap and hold the Settings app from your app drawer to place the shortcut on your home screen.
eyz
has anyone tried CM oin their pad?
will be trying it out either today or tomorrow.
buzzmario
hi in facebook, when i click on certain link, it will bring to the internet browser, however it is chorme, any way to change the internet browser?
also when the internet browser has a video to play, it dun play at all? why? thks
nightkids7089
Wah jialat. I think my MiPad uplorry already.
Plug in for 12 hours already still at 53% charge :s22:
:eek::eek::eek:
yeah.....me tinking like that also....Read Nvidia Shield thread, seems problematic also.....:(
i'm going to lun and see wat samsung will have for the March MWC (?) :o
