XiaoMi MiPad
Mr. Bushido
Regarding Facebook and twitter, are there any third-party clients that are optimised for Android tablets?
eyz
just installed cm11 (4.4.4) on my pad.
feels a little smoother. hope that there'll be a Vanilla or CM lollypop version soon.
bundy
i just install the chinese version of the mipad software centre (similar to itune), is there a english verison ? I got my mipad from china,
Thanks
kyleongwl
Thanks
Y do u need to install it?
the pad itself has MiMarket...and google installer could bridge it to be google play supported.
eyz
i don't think there is.
Thanks
dennizm51
Does anyone experience issues with their mipad screen rotation?
I'm having problems with it sometimes after exiting apps or games.
Have to reboot my mipad then the oscillation back to normal..
Firmware problem??
caterham7
Firmware problem??
fyi, you can search in the miui bug sub-forum to see if others are having the same problem. if not, you can post a bug report for feedback
MIUI Android_Bug Report_Free ROM_Xiaomi MIUI Official Forum
login using your xiaomi account you use to purchase your device
wensan
Have a few questions for the Mipad
2) Is it possible to display the battery % life on the top right corner?
Hi, bro, to display the battery indicator in %, try this:
Goto Settings -> Additional settings -> Battery -> Battery indicator -> Percentage. :s12:
wensan
1) Is the Mi app store supposed to be default installed on this tablet de? I cannot seem to find it...
3) How do I install any widget to display more information on the lock screen? I wish to display battery life as well.
As for the qns no 3, maybe can try this:
Pinch the screen with 2 fingers, you will see 4 options at the bottom of the screen: More apps, Widgets, Wallpaper & Effects. Press Widgets, then you will see another 4 options: Toggles, Settings, Cleaner & Contact. Select Settings, you can see all 13 settings there, just scroll left & right, choose the widget you want to display on the screen.
Hope this will help. :s12:
arcturuz
eyz
Carousell has 2 guys selling screen protector bundled with flip case, at 14$ and 15$ respectively.
One is located at Jurong while the other is located at Bishan.
Both have sleep function for the flap, but the flap doesn't stick when it's folded as a stand.
