XiaoMi MiPad
mambo31
Any one know?
All devices will emit some form of heat after a certain period of time.
It depends on how long and how much resources the game uses.
I'm using my mipad bare naked for now and after about half-an-hour of average usage like surfing and viewing movies, it gets warm. Not an issue for me once my case arrives.
curo
ooo ok.. Coz i'm using nexus 7 (2013) It gets really hot sometime and i can feel tat heat even w my casing.
I use my bro ipad nake and I dun really have this problem. Thats y i'm asking.
Thanks
mambo31
Thanks
No worries.... now that u mention it, my ipad 2 also does not heat up as easily as my mipad.
curo
Ya, I read a review on the mipad that it heat up easily. Then I realised tat my nexus also the same. Reason been ipad is metal casing else mipad and nexus are plastic.
d3n
those order the Mi Pad case with me please check pm :s12:
Kyururu
Recently took back mipad from my wife, since it supports hearthstone now. :D
So far so good except for a few issues like the "loading launcher" lag and the bad support of multitasking. Heard that they are still working on a fix.
cscs3
You are right But it all depend on the design in how fast can these heat be taken away. Otherwise the build in firmware will start throttling the CPU speed to reduce heat.
kashix
How's the performance uh? Playable? Looking for a tablet to play HS, any other recommendation? No cellular right?
mambo31
It's definitely playable... but still imo not as smooth as ios...
and you're right, no cellular... but I hotspot it with my phone or use wifi when I'm home.
might be looking to get one of those portable mifi things as I've got a spare 1GB data card lying around...
mambo31
Btw where to buy the mipad now? Online or available at retail shops?
think it's currently sold out from their main online webstore... but you can get it from local shops at a marked-up price... or you can try marketplace forums, some ppl selling it off at purchased price... or carousell! :)
kashix
Main thing I buy for is hearthstone and watch show/movie. But I thought the gfx specs is powerful, how come hearthstone performance not good? Not optimized? Okie but need hotspot like troublesome sia :(
eyz
just go to marketplace and buy. a lot are selling below retail price for opened set.
some are selling 10$ profit only.
mambo31
That's my main purpose too... mainly to watch movies and bcos it's expandable up to 128gb, I don't need to worry about not having enough space for my movies.
Lagging I think it's inevitable for andriod os... seems that there's always some form of lag
eyz
try cm11, at least you won't see the loading launcher anymore.
d3n
i just dl letv from indonesia during CNY and now i can download dramas to watch! :s12:
but how to change the option to store the dramas on my microsd card? :s22:
need to root?
daymond85
need to root?
Yo, what is the app? I am gg to Indonesia soon. What kind of movie or drama can be download?
d3n
LeTv
lots of chinese dramas :D chinese movies occasionally.
if u download LeTv in singapore... will not be able to download unless using vpn.
d3n
those ordered Mi Pad case from me, please check pm for order status :s12:
