LG G3
Oinkize
not sure whats wrong lens is perfectly fine
if i use flash the picture looks like that got a misty frame
if nv use flash then still ok
my firmware:
any advise?
Are you using any casing?
9N1Y9N1Y
ya using a transparent casing since day 1.
problem occur recently not sure isit due to the update
Oinkize
Try to take picture without the casing?
If it happens you can only do 3 things.
Clear camera data and cache, factory reset phone and try, if still same then send in to service centre.
9N1Y9N1Y
Hmm without case also same. Thing is its not always got sometime have sometime dont. Will try the methods suggested
Domoban
Hi guys i have a problem and hopefully someone here can help. i have a g3 and the top half of the screen is not able to recognize input. i managed to seperate the lcd and digitizer but nothing seems to be wrong. any solution to this problem? or where can i get a replacement in singapore or online? many thanks :)
xRenol
Still under warranty?
If yes, then pay a visit to LG Service Center.
Shadow79
Hi guys, I am thinking of rooting my G3. Does it has trip anything like Samsung Knox? Asking just in case I need to send back the phone for servicing.
killerslayer92
anyone facing screen popping out issue? its out by 1mm on the bottom left corner. considering this is a 8.9mm phone 1mm is more than 10% popped out thickness.
press it down but it pop out again. gonna send for servicing but wanna find out if this is common
KeYoKe
Just switched to lg g3 from iphone 6. Can i check how to update to v20c? Ota update shows v20b update available only.
Edit: ok saw is on lg pc suite
